Question about Necchi 3537 Mechanical Sewing Machine
Suddenly my needle became loose and when I tried to reinsert it as the manual instructs (flat side facing away) it now hits the metal plate. I think this is an easy fix because it seems to me that this happened years ago when I used to sew a lot just can't recall how I might have fixed it.
  • Necchi Master
  • 7,365 Answers
Sounds like the needle is bent & needs to be replaced.
check your throat plate to see if there are any burrs on the plate because they can snag the fabric
if you feel any burrs on the plate take it to a service dealer to have the burr removed
Posted on Jul 29, 2010
When doing blanket stitch why I the needle hitting the plate and breaking on my piaff quilt expressions 4
Hi, is your needle inserted all of the way up? Is the needle bent? Sometimes, that is the problem Try a new needle and insert it with the flat side facing away from you. Good luck.
Nov 20, 2017 | Sewing Machines
How do you adjust the needle position.
Do you have the needle facing the correct direction when installed in the machine? Consult the owner's manual. The flat side of the needle needs to face a particular direction.
Feb 21, 2016 | Sewing Machines
Pixie plus sewing machine needle does not go down into the bobbin but hits the metal plate on top of the bobbin. The needle cannot go through the sewing slot.
Sounds like your needle is set to off-center. Check your manual. You may have a straight-stitch plate in your machine but you have it set to stitch off center or it is set to zig-zag stitch and the needle is unable to clear the stitch plate.
Aug 13, 2015 | Singer Pixie Plus Sewing Machine
Machine stitches 2 0r 3 stitch then skips stitches on rest of seam
try changing the needle
Sewing machine skips stitches
needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Jun 01, 2012 | Janome 6019QC Mechanical Sewing Machine
When I sew the needle hits the pressure foot. I think there is a problem like the shaft that the needle attachs to might be crooked and then it hits the pressure foot it won't go into the hold.
Your needle is probably bent, put a new needle in and make sure that you insert it with the flat side facing away from you. If, you do not have a manual, go to brother-usa.com and download one for free
Sep 09, 2010 | Brother LS-2125 Mechanical Sewing Machine
The thread on the bottom skips stiches and is coming thru to the top
Here are several solutions to try.
* Re-thread your needle It may be threaded incorrectly (backwards).
* Reinsert your needle and make sure it goes all the way into the holder and that it’s positioned correctly. Usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
* Change your needle it may be bent, or otherwise damaged. Make sure your needle is appropriate for the type of thread you’re using.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either).
* Adjust the pressure of your pressure foot as it may be too light for your fabric.
* Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Adjust your thread tension as it may be too tight or too loose.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Note: After changing your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps
Dec 29, 2009 | Singer 1725
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Whenever I zig zag my machine skips stitches.
Try these solutions.
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
*Change your needle
Your needle may be blunt, bent, or otherwise damaged.
*Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
And make sure your needle is appropriate for the type of thread you’re using.
It may be too light for your fabric.
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
Important: If you change your needle plate, check to make sure your needle aligns perfectly with
stitches.
I hope this helps you.
Sep 15, 2009 | Bernina Activa 130
Sometimes my machine will skip a stitch
Here are a few things to try.
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either). Make sure your needle is appropriate for the type of thread you’re using.
Important Note:
After changing your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Sep 12, 2009 | Singer Sewing Machines
QE 440 BSR sewing along fine then skips 2-3 stitches, bobbin seems to not catch the stitch.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens or a universal needle for either. Make sure your needle is appropriate for the type of thread you’re using.
Important Note:
I hope this helps.
Sep 09, 2009 | Bernina Sewing Machines
Necchi 3537 Mechanical Sewing Machine Logo
125 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
