Question about Refrigerators
We have a GE Fridge model# GTS22WCP and the ice keeps sticking together in the bin. Is there something simple that could fix this problem? Thanks!
We have a ge refrigarator at work and the ice taste really nasty. in the begging it was edible but now its really nasty.what to do
Posted on Dec 13, 2010
    Genius:
  • 1,073 Answers
Empty the ice bin once every two weeks, it keeps it from clumping and a bad taste in the ice
Posted on Apr 23, 2008
My ice maker on model#rf267aers keeps getting clumping together ice in the bin? Also notice Ice cycles from top area when bin is removed? how to dis assemble or what part might need to be replaced?
defrost cycle will cause ice to melt slightly and stick together. If it happens too often, it may be cycling the defroster too often. That may be caused by opening the freezer too often.
Nov 27, 2016 | Refrigerators
The pipe that poors the water keeps leaking into bin
That is caused by a leaking water control valve on the side of the dual water control valve. Seee if you can locate the model number around door frame or inside wall of fresh food compartment. I will show an example of what to look for behind the refrigerator. Click here for=> Appliance Model Number Locations and once I know the model I will send a Service Manual. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
May 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Side By Side refrigerator. Freezer melts ice together
Call GE since this refrig is still under warranty . But , you should turn your freezer to 0 degrees first .
Jan 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
GE Top Freezer Fridge - Freezer Buzzing
If you remove the half moon cap, and two 1/4" screws you can remove the cover and get to the fan. The fan motor shaft is mostly wobbling around making the buzzing sound.
Jun 28, 2009 | GE GTS22WCP Top Freezer Refrigerator
Ice cubes taste bad
there should be one in the frigerator for the water if not go the the local home depot and get a inloine on for it.
Apr 20, 2009 | GE GTS22WCP Top Freezer Refrigerator
Gts22wcp Fridge with overhead freezer
Before you buy anything, defrost your unit completely. The problem is often from frost on the fan or shroud.
Many sites such as repairclinic.com have expanded diagrams for various models. You can order from them. They're fast and they are priced reasonably.
Jul 23, 2008 | GE GTS22WCP Top Freezer Refrigerator
Ge freezer problems
check the defrost heater it could be bad if it is good change the sensor on the top of the evaperator coil it is white and about 1 inch long, has white wires connected to it
May 06, 2008 | Refrigerators
GE GSH22JFRE WW not dispensing ice
Deb, sounds like your dispenser control board has given up the ghost. The boards come in 2 models, 4 button and 5 button. The 4 button part # is WR55X10443 (~$87.00)... the 5 button part # is WR55X10437 (~$97.00). Not too difficult to replace. UNPLUG YOUR FRIDGE!!! Remove the drip tray from the dispenser, and any screws hiding in there. Then, using a flat screwdriver and starting at the bottom of the fascia, pry the fascia away from the door and remove. Then remove the screws holding the control in place and disconnect any wiring. (Don't forget to pay close attention to WHERE the wires connect and HOW the wires are routed!) Then install the new board and rebuild. Approx. repair time for your first one is ~1 hour. Good luck!
Sep 24, 2007 | Refrigerators
Ice maker problem, side by side refrigerator
ice in ice bin sort of melts and sticks together and wont dispence out the door . it is a G E
Jul 29, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
