Need to get to printer cartridge to change it on HP 5510xi. Can't open printer.
    Genius:
  • 3,587 Answers
Hmmm..do you have the user manual? That explains how to open the front door and top cover.
Posted on Apr 23, 2008
I have a HP 5500 printer and I keep getting a print carr. error. docs won't print. Is there a patch or something i can do. I have tried cleaning and buying only HP carr. Please help Jeff
Is it a PRINT CARRIAGE error or a PRINT CARTRIDGE error?
Try accessing the manufacturer's web-site: http://support.hp.com
and enteringing '5510xi' and doing the search.
Then, click on "Troubleshooting" and read the online documents.
Jan 19, 2011 | HP Officejet 5510xi Printer
Machine was working fine yesterday, tried today and got a message, "print cartridge error", See the product documentation for details, this machine is old and I don't have any papers or manuals for it...
try turning off and on, then try taking out the cartridge and reinsert, You may have an "align" or "clean "option" either on the printer or via the printer properties. Simply right click on your printer icon and choose properties. You will also see these options there.
Mar 09, 2010 | HP Officejet 5510xi Printer
Print cartridge error
hi..
try to install and reinstall the cartridge to the printer...
maybe there is a loss connection between the printer and cartridge..
and also clean the tab circuit of the cartridge..and the tab circuit printer carrier where the cartridge is installed....^_^
if the problem still exist try to replace the tanks of the cartridge maybe the tanks was not recognized by the printer...
May 12, 2009 | HP Officejet 5510xi Printer
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
Error of the print cartidge
the print cartridges needs to be cleaned first and rechecked if same error the particular cartridge which is showing error must be replaced.
Mar 01, 2009 | HP Officejet 5510xi Printer
HP Officejet 5510xi All-in-One Printer Error: 0xf0af8004
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Feb 19, 2009 | HP Officejet 5510xi Printer
Ink cartridge
Lift the lid. The cartridges will move to the park position. Gently pull them out and replace them.
Jul 02, 2008 | HP Officejet 5510xi Printer
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
jasbo
jasbo
