Question about Technics SL-BD22 Turntable
I cannot get any sound out through my speakers, everything seems to be working? I am running through an amp
  • Technics Master
  • 5,515 Answers
First of all test the amp sockets. With the turntable disconected plug in a cable to your amps phono socket. Touch with your finger the other end of the cable. You should hear a buzz. If you don't the pre-amp in the amp for the cartridge has failed (perhaps an IC). If you do reconnect the turntable. Now remove the wires to the cartridge. Again touch each one. On two you should a buzz (L&R). If you don't there's a fault in the cord to the deck. If you do the cartridge is faulty.
Posted on Aug 01, 2010
No sound sudenly
do you have sound coming out of your tv at all ?you may have you receiver set to through which bye passes your amp and sound run through to your tv . you may also have changed your input mode on the receiver as well . What cables are you using from you amp to the tv hdmi cables coaxial cables
Jan 02, 2014 | Pioneer DEH-1320MP CD/MP3 Car Radio
No sound out of Behringer BXL3000 speaker
Suspected Faulty PC board Dead Capacitor Or Mod Pot I would suggest returning it for an exchange the problem is your speaker will work on a regular stereo because a stereo powers the sound internally causing the magnets in the speaker to vibrate Headphone jacks are designed to pick up off a seperate circuit board with a different connection to the main board hence the no sound from the speaker.
May 04, 2012 | Behringer Ultrabass Bxl3000
03 chev silverado radio on but no sound
My van radio runs on 2 different fuses- both in the fuse box under the dash. One runs the lights the other the sound. Hope this helps.
Jan 11, 2009 | 2003 Chevrolet Silverado 1500
My amp was bad so i replaced it now my sub does not work i checked the wiring that goes from the amp to the speaker and everything seem to be ok then i put another speaker thinking it might be the sub and...
It doesn't sound like the wiring from amp to sub is your problem.
Is your amp getting a power light ?
Are you sure your remote wire is hooked up properly ?
Check both ends of your RCA cables
Jan 05, 2009 | JBL GT150 Car Subwoofer
Hi, I've just install an alpine power amp with JL 10inch subwoofer, everything seems to be working properly except for the subwoofer
If you have the RCA's running from the head unit to the amp, and the speaker wires running to the speakers then you have it hooked up right. Now If you still don't have any sound then you need to look at the amp to make sure that you have a green light. Still I would use 8 or 10 gauge power wire and then the same for the ground wire, make sure that you have a good ground.
Freakville03
Dec 21, 2008 | Alpine MRP-F250 Car Audio Amplifier
Carver Sound Problems
your going to need this place to download the remedy's for your system http://www.euras.com/repair_tips_1/CARVER/AV505/AV505_CARVER.htm
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Nov 02, 2008 | Audio Players & Recorders
Radio cracking/no sound
I disconnected the amp and ran jumper wires between the two harnesses basically creating an amp bypass everything now works fine.
Jul 14, 2008 | 2002 Chevrolet Monte Carlo
Ok this problem is killing me...
maybe the speaker is bad
First try one thing, switch the rca jacks around and see if the other speaker stops working this time.
If so the problem is in the rca jack or head unit.
If the same speaker is still not working, the problem will be the speaker, you will have no other options left since you changed amplifiers and checked all wiring.
Let me know if this helps you
Jun 18, 2008 | Visonik Dual Bass Box with Amplifier Car...
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
Amp is getting hot
amp naturally get hot but not hot enough to burn your finger.if all the speakers working,no distorted sound(sound clear),the problem might be the ventilation(free air flow) of amp.check the blower fan if working or check the exhaust holes maybe it is blocked. here are the other reasons; 1.)speaker wires touched the chassis ground. 2.)mismatched speaker to amp impedance. 3)overdrive input or u tap low input(from amp) to high output(of stereo) 4.)ur amp is out of bias. u need an audio technician for this... hope this help u...
May 15, 2007 | Alpine MRD-M1005 Car Audio Amplifier
Technics SL-BD22 Turntable Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
