Question about Maytag MDG2706A Gas Dryer
My dryer is not getting hot ,what could be some of the reasons and what do i have to check?
Why doest gas dryer get hot ?
There are a few reasons why your dryer may not be getting hot. A bad thermal fuse, a bad ignighter, or a bad flame sensor. Least likely would be a bad gas valve.
Aug 26, 2014 | Whirlpool Dryers
My dryer wont turn on but the inside does get hot what could be the problem
if the inside is getting hot, by not turning on I'm guessing you mean not spinning, you need to check the belt if this is the case, also, be sure the door safety switch is working, you can check that by simply jumping the 2 wires together, if it runs then, replace that switch, but I would check the belt first if you need any help with that feel free to reply
Jun 24, 2011 | Dryers
Dryer gets severely hot on top and rear of machine,is this normal?
Reasons for overheating can include:
1. Shorted heater coil
2. Bad operating thermostat
3. Worn drum seals (felt seals in back & front)
Use a multimeter to check the coil and thermostat for continuity
Visually check the felt drum seals
Nov 21, 2010 | Frigidaire GLER642A Electric Dryer
Gas dryer is spinning but won't get hot what can I do before calling for repair?
Disconnect the vent tubing and check for any clogged up areas. That will prevent the heat to work vis the moister control sensor. Clogged vents are the number one reason why dryers do not heat up while spinning
Apr 29, 2010 | Dryers
Dryer will not get hot
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it iwll help you find tha thing that is causing your problem..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 06, 2010 | Frigidaire FEQ1442ES Electric Dryer
Clothes do not dry completely on one cycle
Check your dryer vent (the entire length) for lint build-up. Check that the vent is opening properly (the flapper type can come loose and block air-flow).
Those are the most common reasons for an inefficient dryer.
I hope this helps.
(we have had the vent get blocked by the flapper)
Apr 03, 2010 | Whirlpool WED5300S Electric Dryer
LGR5636kq0 model. not drying clothes reasonable time
It could be the tumbler. Also check the vent coming from the back of the dryer (make sure it is not clogged)
Nov 10, 2009 | Whirlpool LGR5636L Gas Dryer
No heat from GE electric Dryer
Possible. Here are all of the reasons why you might not be getting heat. Read them over and get back.
Jun 07, 2009 | Dryers
Dryer turns off after one minute.
Sounds as if your high temperature thermostat is going bad or is bad. Check your thermostats. If your dryer gets to hot this will shut it down for safety reason!
Jan 09, 2009 | Kenmore 66832 Dryer
Maytag MDG2706A Gas Dryer Logo
89 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
