Question about True GDM-12 Refrigerator Commercial
Part number for GDM-07F thermostat - True GDM-12 Refrigerator Commercial
My true GDM-26 never shuts off and my drinks are frozen?
Faulty thermostat, the thermostats are cheap and wear out easy
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 15, 2013 | True GDM-26 Refrigerator
True GDM-10 cooling problems
Turn thermostat to a higher number or replace it.
Dec 18, 2012 | True GDM-9 Beverage Cooler
True gdm 72 goes below 20 degrees
Usually a blocked condenser fooling the thermostat into running overtime. Possibly thermostat fault but less likely
Apr 14, 2012 | True 72 cu. ft. / 2039 liter Commercial...
True GDM-33 refrigerator icing up around the condenser then defrosts leaking water all over the floor.
It could possibly be an issue with the thermostat not shutting off. I would set it at it's setting to see if it shuts off. If not replace the thermostat. Also check to see if the evaporator fans are running.
Oct 29, 2017 | True GDM-33-SSL-54 Refrigerator
I have a True GDM 33 model is it possible tochange the temperatur
If your cooler is constantly running too cold the thermostat is probably bad. I can hook yu up with a thermostat. ;) www.northeastcooling.com
Nov 18, 2008 | True GDM-33-SSL-54 Refrigerator
GDM-26 humidity very high
assuming fridge is at correct temp, i suspect fault is with your humidity detector. the humidity inside a fridge is a lot less than the outside air
Oct 09, 2008 | True GDM-26 Refrigerator
True GDM-12 Refrigerator Commercial Logo
64 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
