Rank: Guru
Rating: 89%, 5275 votes
All 802.11 network devices are compatible, the only difference is speed
(b=11Mbps, g=54Mbps). If you mix b and g only trouble is that network
can be slowed down, for the rest does not make any difference, all
802.11 device are fully compatible.
If you changed network settings, as suggested , ensure your archos is still connecting to wireless networks (other then yours eg public one you tried before).
Static IP configuration on the Archos (explicitly forcing IP to a specific value like 192.168.x.x suggested) may prevent the archos from acessing resources on many networks.
Once ensure PDA is working on other network go back home and do the following.
Ensure that you are connecting to your own network, and not some neighbours' one, check the network ID and verify.
If you are using network encryption (as it should be, unless you want to share it with neighbours and strangers) , ensure you inputed the right key checking on archos network setting. Doublecheck key on your router settings acessing router panel from Internet Explorer.
If you previously tried to remove encryption on router, ensure you used Save All command on router before exiting. If you didnt save router settings after doing changes, router may go back to previous state when restarted.
Turn off all computers on network and restart router disconnecting power cable and plugging back. Connect Archos before starting other computers.This will evidence (if working) troubles from eventual IP conflicts with other computers on network.
If the above did not work it is likely to be a firewall problem. Open once again router control panel inputting router IP from Internet explorer. Go to firewall settings, there will be a setting for Trusted IPs. At this point you should find out the IP assigned dinamically from router to Archos and set it as exeption (trusted IP) on router firewall.
If you cannot find IP use temporarly whole range from 0-255, for example if your nework gives out IPs 10.0.0.x , you set trusted range 10.0.0.0 - 10.0.0.255. If you accept the whole range on server ensure you have encryption back, with this configuration your network will be completely open toany wireless host, unless you activate encryption.
Regards
Comments:
Apr 27, 2008
- All 802.11 devices are compatible , I am just not guessing, this is the reason why we created 802.11(Is one of first things you learn doing any networking course) . No difference but speed in 802.11 a, b , or g standards. evidently is something else.
Do what Ekse suggested, as you messed up your settings without knowing exactly what you were doing.
Hint: Not all experts posting here have a knowledge of networking and a perception of what the problem his , do not do immediately whatever is suggested unless you know you can bring device back to initial status settings.
Reset PDA and connect to network.
Apr 27, 2008
- I can add more, some post is truly idiot! follow EKSEApr 27, 2008
- or BenimurApr 28, 2008
- Can you connect to your router with any other wireless device, fo example a laptop?
borrow a laptop and test your wireless.
Also test back if Archos is still connecting to wifi in different network.
Post results here
