Cant change the 8888 on digital satellite receiver st875d not getting picture or sound out of television
3 Suggested Answers
SOURCE: rca l32wd250 telivision
I have seen this posted on Google under RCA service bulletin #TV09-001 which states it is an open fuse on the digital board causing the symptoms. Not something I would recommend for a consumer to fix since it is a surface mounted fuse that is soldered to the circuit board. Very repairable by a service center. Good luck!
Posted on Dec 10, 2008
BElectric
  • 1140 Answers
SOURCE: My Sony Bravia television froze
Your TV has a dual tuner - one for analogue and one for digital although they are contained on the same tuner board. It's possible that the digital tuner has failed, in which case the tuner board will most likely need to be replaced, but often this problem can be resolved with a "hard" reset. Turn the TV off and unplug it. Remove all the cables from the back, leave it for at least 5 minutes and then re-connect only the cable from the tuner source. i.e aerial/antenna. Make sure you are in Digital TV mode (DTV), then run the channel scan again.
If it works turn the TV off, re-connect all of your other devices and you should be able to resume using the TV as normal.
If this doesn't work, you may need to have the digital tuner replaced. The analogue and digital channel feeds are from the same source. As the analogue channels are working there is no obvious fault with the feed or cables.
Please try this first and then post back for further assistance if needed.
Regards,
BElectric
Posted on Dec 23, 2010
How do I reset a phoenix digital satellite receiver dvb 2800A without a remote it asks for a pin but I cant put one in without a remote
How to Reset the Phoenix DVBS2500A Digital Satellite ...
www.ehow.com > Tech
The Phoenix DVBS2500A is a digital satellite receiver built to capture free-to-air ... isno charge for accessing and viewing programs that the Phoenix can receive. ... press 7799 on the Phoenix remote control, and then press the "Enter" button.
How to Connect & Install a Digital Terrestrial Receiver ...
? 1:32
https://www.youtube.com/watch?v=bZzuN4a8GGE
Mar 2, 2012 - Uploaded by tvtradedave
http://www.tvtrade.ie/digital-tv.html. ... Up next. How to watchdigital channels without cable TV or satellite for FREE? ... TDT Colombia DVB-T2 Decodificador Multitech TDA Television TVDigital Terrestre Caracol HD RCN HD ...
PDF]Cisco D9865 Satellite Receiver Software Version 2.15 ...
www.cisco.com/.../Digital_Receivers/47-4035197-01_D.p...
Cisco SystemsModifications to this product not authorized by Cisco could void the FCC approval ...This Class B digital apparatus complies with Canadian ICES-003. ... Cisco D9865Satellite Receiver Installation and Configuration Guide ..... Performing a Factory Reset4-39 .... Provides an overview of the front panel and remote control.Missing: phoenix
Jan 07, 2016 | Televison & Video
2 sec Blip to picture
Are you saying that this happens only when you are using the RF input? Is it not happening when you use the video input from the satellite receiver? Try a DVD player on the input of the video where you now have the Satellite receiver connected. Let me know exactly what you mean as i need a little more information so I can assist you.
Jul 14, 2007 | JVC HD-52G886 52" Rear Projection HDTV
I have a 46 Samsung and when I turn on the TV I get sound but no picture. I get tv menus, sat menus, and dvd's work but no picture on sat.
The problem of your tv is only the connection or the digital receiver. Try to check the cables that are connected in your tv specially the input,output of the digital receiver or use another cable for the video in of your tv if still no picture try to contact your satellite service provider the unit is may be defective. good day and hope that it may help thank's.
Jul 14, 2011 | Samsung LN-T4665F 46 in. LCD Television
I have a 19 " sansul cant get my ilive sound bar
I hope this helps. You have to connect your sound bar to your cable box/satellite tv receiver. If you are connecting with composite or component cables you connect the video cables (either the yellow or the green blue and red cables) between the television and the cable box /satellite tv receiver. Then you connect the red and white audio portion of the cable between the cable box/satellite tv receiver and the sound bar. You are going from the OUTPUT of the cable box/satellite tv receiver to the INPUT on the television and sound bar. You use the function/source/input button on the sound bar to choose the space you plugged the cables into on it or listen to the radio or listen to your IPOD and etc.
Jun 10, 2011 | Sansui HDLCD-1900 19 in. LCD Television
I have a wf24t5 that i want to connect to a dish sat hd. how and what do i need to do to connect?
After confirming by viewing the operation manual for this unit, this TV is only capable of inputting a baseband video and standard audio. Unless the Satellite Receiver you have has those type of output jacks then this TV will not be able to reproduce picture or sound from the Receiver. It may be possible to connect through the antenna connection but again the Satellite would need a connector that would output on Channel 3 or 4. Most recent satellite receivers do not offer these ouputs. You indicate that the Receiver you have is High Def. The TV you have is not high def and would drastically down grade the quality of your picture and audio being delivered by the satellite receiver
Television system: NTSC-M
TV Standard
Closed Caption
System: §15.119/FCC
Channel coverage
VHF: 2 - 13
UHF: 14 - 69
CATV: 2 - 13, A - W,
W+1 - W+84,
A-5 - A-1, 5A
Tuning System: 181 channel
frequency synthesized
tuning system
Channel access: Direct access keyboard,
programmable
scan and up/down
Terminals
Antenna input: VHF/UHF/CATV
75 ohm unbalanced
(F-type)
Video input: RCA connector x 1
(1 x Front)
Audio input: RCA connector x 1
(1 x Front)
1 speaker
ELECTRICAL SPECIFICATIONS
Sound output: 1W, 8 ohm x 1
OTHER SPECIFICATIONS
Remote control: Digital encoded
infrared light system
Operating
temperature: 5°C to 40°C
(41°F - 104°F)
Power requirements: AC120V, 60Hz
Power consumption
(Maximum): 98W
Picture tube: 23"
Dimensions: H : 20-3/8" (518mm)
W: 22-13/16" (580mm)
D : 18-7/16" (469mm)
Weight: 55.1lbs. (25kg)
•Designs and specifications are subject to
change without notice and without our
legal obligation.
•If there is a discrepancy between languages,
Feb 18, 2011 | Symphonic Televison & Video
HD channel picture is clear, but regular digital picture scramble
o.k. check all your connections
if you have a newer house check to see if you have a main hub in a closet somewhere and check all connections. Check your hd receiver and you may be able to chage the DPI the receiver receives in.
I have this problem on some of my non HD channels, also. So much for going digital. I get fuzz and pixel problems "from time to time", but, if it is really bad and consistent your should call your service provider.
Things to ask also ? are you using cable or satellite.
If satellite T.V. there are other reasons you could be experiencing problems.
hope this helps!
Mar 26, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
Everthing won't be completely shown on my television.
It sounds like you have the picture"ratio" set or adjusted wrong, find the button on your remote labeled "ratio","format","wide" any of those,then just press the button multiple times until you get the full picture that you are looking for. If you have digital cable or satellite those receivers also have picture format adjustments in their menu system that need to be set for your type of TV screen(wide 16:9 or standard 4:3). If you need help, your cable company or satellite provider can assist you with info. Good Luck ! P.S. don't forget to refer to your owners manuals.
Dec 02, 2009 | Zenith Z32X31D 32" TV
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
