Question about Dell Latitude C600 Notebook
Dell latitude wont read 256 megs of ram only 128
  • 903 Answers
The c600 can handle up to 512MB of RAM, so it's likely one of your RAM sticks is bad or not seated correctly. Are you using two 128MB sticks? Remove the stick from the second slot and turn on the computer with only one stick installed, and see if the RAM is recognized. Then take that RAM out and try the computer with only the other RAM stick -- if either is not recognized, that stick is bad.
If both are recognized, try reinstalling both RAM sticks and see if the computer will recognize them. If not, make sure they are both seated properly. You may have a problem with the second RAM slot if it is still not recognized. If you have access to other RAM, try that too and see if it is recognized.
Posted on Jul 30, 2010
Will a Samsung 256MB DDR PC2700 CL2.5 184 PIN work
No that memory is not compatible. The Precision 350 uses memory called RDRAM aka RAMBUS.
Here are the speeds and sizes that are supported.
Memory modules supported PC800-40: 64-, 128-, 256-, 512-MB, non-ECC or ECC
PC1066-32P: 128-, 256-, 512-MB, ECC and 64-, 128-
,256-,512-MB, non-ECC
Minimum memory PC800-40: 128 MB non-ECC and ECC
PC1066-32P: 128 MB non-ECC and 256 MB ECC
Maximum memory PC800-40: 2 GB non-ECC and ECC
PC1066-32P: 1.5 GB non-ECC and ECC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/benjamin_29adbb94bfb43281
Sep 27, 2014 | Computers & Internet
Can i use a ddr ram in a dell latitude c600 notebook
hi simply NO this is sdram as here are the specs for this laptop Memory Architecture SDRAM Memory module sockets two user accessible SODIMM sockets Memory module capacities and type 64-, 128-, and 256-MB
3.3-V SDRAM SODIMMS 1 Standard RAM 64-MB memory module Maximum RAM 512 MB Memory clock speed 100 MHz Memory access time CL2 or CL3 (Note: CL3 indicates a CAS latency of 3 clocks) BIOS address F000:0000-F000:FFFF
hope this helps
Jan 10, 2011 | Dell Latitude C600 Notebook
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
My Dell C600 won't recognize the 2 new 256 mb sticks of RAM
i think you need a same brand of 256 for it to work? and when you buy something for your computer make sure that the one you both is the same brand or code with your 128 for example you have 128 ddr2 sdram so you can only upgrade it with 256 ddr sdran or 512mb,1gb,2gb ddr sdram.
May 01, 2009 | Dell Latitude C600 Notebook
Toshiba Satellite 1805-s253 memory upgrade
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
Mar 13, 2009 | Toshiba Satellite 1805-S253 Notebook
Add ram memory to a Dell Latitude CS Series
go to crucial.com and use there online tool..that will help u!!
Nov 16, 2008 | Dell Latitude CS Notebook
How to upgrade a Dell Latitude CPX - Intel P3 500-650 laptop
I have a CPX H500GT. To get it to run XP Pro to run right, max out the ram. And get a larger harddrive. Xp uses a substantial amount of space.
Sep 22, 2008 | Dell Latitude CPX Notebook
What are the ram limits on a compaq presario 5000a. I put 256 ram in the compaq and it only reads 128. Why?
You can install up to 3 sticks of 512 mb of memory. Did you add a 256 stick to the already-existing 128? You need to put DDR266/PC2100 memory. To troubleshoot, remove the 128 stick and put your 256 in and see if it is recognized. You will know right away from the bios screen. Memory needs to be the same type.
Jul 16, 2008 | Compaq Computers & Internet
Dell Latitude C600 Notebook Logo
69 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
