I have a CTX s761 lcd monitor. The image on the screen will be clear for about a minute, then it gets very dark and can only see a ghost of the image. Power off and back on and it does the same thing again. Any suggestions?
  • Computers & ... Master
  • 5,531 Answers
It's a backlight issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) With a bad backlight, you'll usually see a very dim image if you look at the monitor from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something).
The backlights are sandwiched on the perimeter of the monitor (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your monitor size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx . lcdparts.net sells backlights for some laptops and monitors. There are other sources.
The inverter board or the video board can also fail but you usually won't see any image when those fail. For an out of warranty monitor, open up the back of the unit and remove the shielding. Then look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the monitor. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the monitor while the box is open). Similarly a good inverter can test the backlight. If the inverter or video board is bad, you will see nothing
I hope this helps.
Posted on Jul 27, 2010
My monitor is listed as default and I can't change it. I just want a driver for my CTX S761 that I can download without having to buy something.
The software driver/installer to your monitor could be listed or found at http://www.cnet.com. Please go to that website and on the search area, type the brand of your monitor then the word "driver", then it will show the right driver that fits to your monitor. Download the driver from the net and run it. All questions that pop up should reply with affirmative reply. Good luck!
Sep 20, 2011 | CTX S761 17" LCD Monitor
How can unlock the key
try looking in the manual for a default password, have you tried 0000 or 1234?
Mar 09, 2011 | CTX S761 17" LCD Monitor
When I boot my system, it tells me the setting is
The native resolution for this mnoitor is 1280 x 1024 @60 Hz. It is either you do not have the correct driver installed for yor video card or your mnoitor has the problem inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | CTX S761 17" LCD Monitor
My CTX model S761 LCD monitor flickers and I think it needs new bulbs. Do concur that is the problem? Where can I find new parts?
The "bulbs" in LCD's are CCFL tubes. Similar to the long flouresent lights you see in office buildings etc.
If they are blown, then they don't flicker.
Chances are the inverter circuit, what powers those tubes, is failing and should be looked at by a qualified technician.
Hope that helps =)
Apr 08, 2008 | Computers & Internet
New CTX x762 LCD Monitor
inside the round bit there is a bolt its very tight but you will have to dissasemble to get to it apart from the obvios ones there are 4 hidden behind rubber covers on the sides and then th fron frame unclips this i difficult to start off but by the power button on the side there is a square lump of plastic sticking out place a flat head skrewdriver between this and the front lip and gently twist and the first clip wil come undone and from there you can get the rest good luck
Feb 01, 2008 | CTX S761 17" LCD Monitor
New CTX x761A Monitor
No way, it's fixed joint... that is due to the design that balances the screen avoiding it from falling or stumbling down.
Hope I gave you the idea... Fixya!
Executable driver download for CTX S761 lcd Monitor
Searched the CTX site found the device in discontinued products but no link.
This one actually has 761 in the name -- you did not list what you have found so I hope this is new.
http://members.driverguide.com/driver/detail.php?driverid=517451
Dec 20, 2007 | CTX S761 17" LCD Monitor
Computers & Internet Logo
104 people viewed this question
Alun Cox
David Payne
David Payne
