Question about Kenmore Slider/Casement Air Conditioner
Bought Kenmore window AC #70121 12,000btu yesterdat for our garage. Works fine but was no drainage hole for water which was collecting rapidly. Did drill drain hole. Is this a problem?
4 Suggested Answers
  • 266 Answers
SOURCE: i drilled a hole in
The drain hole from the front to the back is plugged or the unit needs to be tilted more toward the outside.
Posted on Aug 12, 2010
baraquielnar
  • 247 Answers
SOURCE: I need the price of a motor for a LG gold
it is more or less 130$ try to canvass.
Posted on Feb 01, 2011
  • 4736 Answers
SOURCE: My 5200 wall air conditions
The outer drain hole is the only one that needed to be cleared. But, keep and eye on it, as there may be some floating debris in the drip pan. You said the unit is angled enough at the rear. So, I'm assume you have at least 1/4" to 1/2" downward tilt at the rear of the unit. If that's the case, for now, that's about all you can do. Unless you have a Wet/Dry Shop Vac. In which case you could **** the water out of the drip pan after removing the front panel of the unit. If you attempt this, be sure the Master ON/OFF switch on the unit is OFF and the unit is unplugged.
Hope this helped you and thanks for choosing FixYa.
Posted on Aug 26, 2011
Where is drain plug
Usually on a window AC there is no drain plug. It relies on the tilt of the of the AC. The AC should be installed with a slight rear tilt so the water flows to the rear to where there should be two factory drain holes. Besure to get proper drainage otherwise the fan will pick up water and blow it into you house and cause humidity. I have also drill a hole on the lowest location on the bottom of the chassis to help drain it seven better. Your AC depending on where you live and how humid it is will collect more water on a humid day than a dry day and also the effenciancy will be worse on a humid day.
Jul 07, 2014 | Goldstar GWHD5000 5,000 BTU Window Air...
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
Our window air unit is leaking into the house. It was purchased it earlier this summer and has worked fine until now. We don't see a drainage hole on the outside and the manual said nothing about a...
Two things can cause the problem you're having. Either separately or collectively.
1. The drain hole in the drip pan near the rear of the unit is clogged.
Sometimes finding the drain hole can be a challenge. As the clog will blend in with the hole. Patience & persistence is what is needed in locating it. A pipe cleaner works well to clear the clog.
2. The rear of the unit does not have enough downward tilt.
The general rule of thumb for rear downward tilt is 1/4' to 1/2". This allows the water to flow to the rear of the drain pan and thru the drain hole. Rather than into the house.
Hope this helps you & thanks for choosing FixYa..
Aug 19, 2011 | Heating & Cooling
My Kenmore window ac unit cools ok but makes a clicking/clacking sound while it runs. The cooling fan turns properly and it drains outside but has started to drain a little inside-it is angled to drain...
From everything you described, it sounds like more water than usual is collecting in the drip fan. Despite the unit draining out the rear drain hole. Check the drain hole to make sure it is totally clear and not partially clogged. A pipe cleaner works well to do this. Be sure to turn the unit OFF & unplug it, before working on it.
Hope this helped you and tanks for choosing FixYa.
Aug 15, 2011 | Kenmore 76100 Wall/Window Air Conditioner
We have a hotpoint RLA 34 ( MICROBAN ) FRIDGE . water keeps seeping into the bottom , under the crisper box tried turnining temp down , made sure it's level , no blocked drainage hole . door shuts tight...
You said no blocked drainage hole, where was the drainage hole that you checked located? Did you pour water down this drain, and furthermore did you check that the water you poured into the drain flowed into the condensate pan on the outside of the fridge? Unless you have a problem with an ice maker leaking water, it sounds very much like you do have a blocked drainage hole, otherwise known as a defrost drain. the drain system begins underneath the evaporator coil inside the freezer, this is where the water that is collected in the defrost cycle flows into a drain tube that leads the water down to the condensate pan. The best and safest way to clear out this drain is to blow it out with compressed air, after you remove any and all ice at the beginning of the drainage system, in other words, the hole located underneath the evaporator coil.
Nov 09, 2010 | Hotpoint RLA31 Compact Refrigerator
A.C. unit is draining on the inside of the house.
There is a drainage and it is stucked with dust, mold etc. Just open metal lid on the wall inside your house, where the coil is installed and where you're changing filters, remove air filter, there at bottom you will see the drainage hole (now under water probably). Rent an air compressor from Home Depot or Lowe's, stick the hose to that hole and turn compressor on. This shall blow the drainage through. After that slowly pour 1-2 cups of Chlorox or Tylex in there, let it stand for 15 minutes, then pour some more water and blow with compressed air again, then flush it with water and blow last time.
Do that at least once in two years, or you gonna have same problem again.
Sep 14, 2009 | Frigidaire FAC126P1 wall/window Air...
Continuous drainage
Take out the drain pan and look in left hand top of the compartment and you will see a drain hole for the pan.Plug the drain hole with a small rubber plug, I used an electrical wire nut wrapped with tape and it worked fine.replace the pan and the water will run out the back. A 3/4" garden hose should work for the drain hole.
Jul 27, 2009 | Haier HDN655E Dehumidifier
AUDI A4 2000 - water collecting in battery/wiper wells
The drainage in the wells are blocked with leaves or debris clean drainage holes and that will solve the problem. Good Luck
Jan 22, 2009 | 2002 Audi A4
Connecting a drain hose
Most units have a drain connection, either on the machine itself, or in the collection pail. These connections usually fit standard garden hoses.
Jul 05, 2007 | Maytag M3DH30B2A Dehumidifier
Heating & Cooling Logo
282 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
