Printer is making rumbling sounds and paper gets stuck half way thru printing in toner cartridge
  • Anonymous May 08, 2008
    Paer gets stuck in printer
    Problem Solver:
  • 4 Answers
Replace the paper pcik-up rolly assembly. MAKE SURE TO get a good look at how the existing one is installed before removing it. It needs a little tweeking to get the new one in and everything lined up correctly.
Also replace the separation page on the paper tray itself.
Look for part number PF-1 Kit or OEM PART #: LJ7920001
The only diagrams I could find on-line of the inside of the printer I found by searching for "brother pl-prn067". Look at pages 8-9.
Posted on Feb 02, 2010
Sounds like a worn pickup roller.
Posted on Aug 13, 2008
Why is my printer making really loud grinding noise and will not feed paper or print
It sounds like a bit of paper is stuck somewhere in the paper feed route. Remove the toner cartridge and any other bits that pull out. Removable bits often have a green tag or finger grips moulded in to them. Do a careful check in the printer for any bits of paper or even a full sheet stuck somewhere. Carefully remove all rubbish and reassemble.
Dec 01, 2014 | HP LaserJet 1018 Printer
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
HP color laserjet 2840 printer. no printing on the left side of the paper.
Hi
No print on the left side indicates that the toner powder on the left side is almost empty. Try to remove the toner cartridge and shake it well if the toner are new.
If still the same, you need to replace new toner cartridge to get better print out.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 19, 2011 | HP LaserJet 2840 Printer
I was printing a 10-page job and the first page just got stuck halfway out of the printer. I tried pressing the reset buttons, tugging gently on the paper, nothing. I tried unplugging it and plugging it...
If the paper is halfway OUT of the printer, that means that the other half is stuck in the fuser.
Open the toner cartridge door and remove the toner. Leave the door open. This relieves tension on the rollers.
Grab the paper as close as you can to the back of the printer and pull the paper out carefully.
Put the toner back in and close the door. You may have to power cycle the printer.
Feb 02, 2011 | HP LaserJet 1012 Printer
How do i stop my printer from leaving ink streaks down the right side of my pages?
I was going to suggest removing the fuser and looking at the rollers, but on this printer it's a major operation.
Instead let's run the half test. Put paper in the manual feed tray(tray 1). Print to the printer. When the sheet of paper gets pulled about 3/4 of the way in, open the top cover. Pull out the toner cartridge. Look down at the paper. Does it have a streak down the right side? If yes, replace the toner, if no, have the fuser replaced.
Oct 21, 2010 | HP LaserJet P2015dn Printer
Paper Jam Toshiba 250
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks! mannu_rakesh
Aug 31, 2009 | Office Equipment & Supplies
HPlaserjet P1006 Series When printing getting a white blank streak down the middle of the page
To isolate the problem you need to do a 'half test'. This involves printing and stopping paper half way through the printer. This can be done by opening the toner door at the appropriate time. The paper should have just entered the fuser (watch out, the fuser is HOT). You should see the paper with the printing on it after removing the toner cartridge. Carefully turn the toner cartridge over and move back the door that covers the drum. DO NOT TOUCH THE DRUM. If there is the corresponding blank spot in the center of the drum, like the paper, the scanner is dirty or blocked. A can of compressed air will help here. If you have access to a different toner cartridge, you may want to try that first.
Jul 20, 2009 | HP LASERJET P1006 Printer
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Ink casette error
If you just put new cartridges in the printer, check to make sure you removed all of the protective plastic wrap that may be required to remove prior to printing.
Also, check the cartridges by removing and replacing each one. make sure there is no obstruction, or torn papers, that may cause a jam or other problems.
Also, after verifying all that. Use the printer utilities to run a test. Hopefully that should fix or clarify if there is any other problem.
Hope that helps..
~enov8
Mar 07, 2009 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Samsung CLP-300 Laser Printer
Try changing the printer toner cartridge first if not make sure that the paper of where the paper is stuck if under the toner cartridge check that there if there is any print on it and that it is entering the fuser section. If it has stopped at the fuser section then the possibility is that the fuser drive gear is broken or some teeth missing. If the paper is stuck before the toner cartridge then there maybe the pickup tyre dirty and not feeding correctly the other thing there maybe a sensor arm stuck down.
Try the above
Thanks J
Jan 19, 2008 | Samsung CLP 300 Laser Printer
260 people viewed this question
jasbo
jasbo
