I have a Roadtrek class B rv and when it rains, i have water coming in the rv just underneath the AC unit. It appears that the AC is sitting inside a self contained box and it looks like it's only open to the rear. However, when i take the cover off from inside the rv, i can see that the water accumulates in the bottom........it should drain outside but it doesn't even when i'm at a small incline of maybe 3-4%, the back being lower than the front. Pls help. Tks
cj2176
  • 520 Answers
SOURCE: Water not draining out the back
Check the weep holes in the bottom of unit. It is holding water and when it does flood itself it will be inside with you.
Posted on Jun 23, 2009
BIKER T
  • 909 Answers
SOURCE: rv ac unit leaks, even when fan only
Where the pipes enter the building, look carefully there for a bad seal. Use a good quality sealant and block the leak properly. If there is no rain, and the unit is leaking still with the fan on only, then you have an issue with the drain pipe angle or a kinked pipe or a blockage. Suggest you have it seen to by a aircon. technician as that repair is really not easy.(AC will possibly have to come out to rectify problem).
Posted on Oct 17, 2009
motor1258
  • 6674 Answers
SOURCE: water dripping out of rv ac into rv.
Is it a ducted system? If yes, check that there isn't gaps between the divider that separates return air at the front, with forced(cold) air. You can usually use a flashlight and look for gaps, or even (very carefully) feel it blowing cold into the warm air return. If you find some gaps, buy some foil tape, and tape them off good and retry and see if it still happens. Some older units experienced cracks in drip trays that allowed condensation to drip inside as well. Get back to me with year of your RV, and whether it's ducted or non-ducted system, and perhaps I can guide you better on what to look for.
Posted on Jun 22, 2010
  • 3074 Answers
SOURCE: On my LG window AC
usually in the middle underside of the window units is a hole that water drains out of, you can always drill new holes in order to make it drain, Good Luck Tim
Posted on Apr 24, 2011
  • 4736 Answers
SOURCE: ac unit keeps reading fl
After reading over the Owner's Manual for your unit, I wonder if you are operating it in the Cool & Dry Mode. If that's the case, the dehumidifier is in operation, which would account for having to drain the unit every 2 to 3 hours. Ideally, the Cool and Dry Mode should only be operated for about an hour, when the unit is first started . Removing the humidity will allow the AC function to cool more effectively. But, it is not necessary for it to remain in Cool & Dry mode all the time. Because the AC itself unit will remove some humidity too.
Hope this helped you to troubleshoot and solve the issue of having to drain the unit every 2 to 3 hours
Posted on Jun 27, 2011
Multiple clicking sounds coming from AC unit before AC unit turns on or before furnace turns on.
the is a 24v wire that feeds from your thermostat to your unit, inside there is a contactor that engages, this makes a click sound as it really is a basic mechanical part the makes metal touch metal to allow current to flow through the system, perfectly normal, your hearing the low voltage engage the highvoltage at the contactor.
Jun 18, 2013 | Dometic Rooftop RV Air Conditioner
How do I access frozen water pipes?
I am sorry but we have no information like this for Motor homes. Please contact the manufacturer or a local RV repair facility.
Mar 20, 2012 | Cars & Trucks
RV AC is working fine, but the water is leaking from the ceiling Where is the drain tube on the unit, The AC unit is a roof type, Duo Therm serial # 43404934, Part # 3105459
Normally, the condensate will drain out of the unit onto the roof and off the edge to the ground. Remove your cover inside (probably 2 screws) and tighten the 4 bolts you will find inside. If they are tight, go to your RV supply place and get new roof gasket. Remove the AC and insert the new gasket and resecure the AC to your roof.
Thanks for your question @ FixYa.com
Jul 26, 2011 | Dometic Rooftop RV Air Conditioner
Water coming from ceiling about 3 foot from unit
Does the unit work other, than the leaking?If it does you need to install a square seal between the ac unit and the roof.You can either buy the seal from Ebay or I would recomend an Rv Repair place.(They Might even be able to install it where the Rv Sits)
Aug 05, 2010 | Dometic Rooftop RV Air Conditioner
I own a 2004 Suzuki Forenza and have noticed that water drips on the carpet when I run the AC or when it rains. We've already taken apart the drain and confirmed that the leak is not from the drain under...
You are exactly correct. There is a drain on the bottom of the evaporator case. Probably need to place the car on ramps or jackstands to get underthere and clean it out. If you don't feel you can do that safely go to a machanic and tell him what you need done. The drain is on the passengers side down by the front floor. Most times it's out side in the engine compartment, but some have a small hose you can get to inside.
Feb 08, 2010 | 2004 Suzuki Forenza
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
Rv ac unit leaks, even when fan only
Oct 17, 2009 | Dometic Rooftop RV Air Conditioner
Rear door power lock--1996 Dodge Ram van (Roadtrek)-- won't open
Check all of your dash fuses inside the glove box if these are fine. Remove the door panel nd check to see that the wires have not come loose they tendto come loose from closing the rear door.
Mar 13, 2009 | 1996 Dodge Ram 1500 Club Cab
Heating & Cooling Logo
192 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
