Question about Precor EFX 546i Elliptical Version 4
I am looking for a parts and repair manual for a precor efx546 eliptical unit
    President:
  • Precor Master
  • 832 Answers
Go to National Gym Supply @ gymparts.com or call them @ 1-800-496-7278
Posted on Jul 29, 2010
  • John Mazmanian
    John Mazmanian Jul 29, 2010
    Go to National Gym Supply @ gymparts.com or call them @ 1-800-999-3756
EFX 546i eliptical battery location
The battery is usually located at the back of the machine towards the top -- there may be a circuit board on top of the battery. And the second link listed below is a technical bulletin for certain models to help prevent damage to the battery during installation.
This link will take you to the 546i models and parts list. You can also find a parts diagram but you will need to match your serial numbers to the ones listed so you can pull up the correct diagram:
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
http://www.sportsmith.net/images/Pick_Docs%5Cp0645969101-BatteryInstallationWarning.pdf
Feb 03, 2014 | Precor EFX 546i Elliptical Version 4
422 code on EFX546 4H model, will not accept code to go into diagnostic mode
This link will take you to information on the diagnostics mode, beginning on page 8:
http://www.sportsmith.net/images/product_support%5Cprecor%5CService%20Manuals%5CCommercial%20EFX%5CService%20Manual,%20C546%20EFX.pdf
Jan 24, 2014 | Precor EFX 546i Elliptical Version 4
Error 44 precor eliptical 546
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Nov 22, 2012 | Precor EFX 546i Elliptical Version 4
Tv flickerig on precore eliptical
Dear Sir:
You must test the power supply inside of TV, if you have skill for to do oit use DVOM, otherwise you must call some service tech, or go to repair shop.
However try to tight every connector wires, for loose, breake(test the wires for continuity) or burn.
God bless you.
May 13, 2012 | Precor C956 Treadmill with Cardio Theater...
Efx546 error 32
Precor Error 30, 31, 32 and 33, Communications Error Probable Cause 1. Bad interconnect cable between upper PCA and lower PCA.
2. Interconnect cable is mistakenly plugged into the CSAFE connector at the upper PCA.
3. Elliptical 5.17 equipped with old software version 1.01 in upper and lower PCA.
4. Upper and lower PCAs have mismatched software.
5. Another component plugged onto the PCA is overloading the +5VDC power supply.
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Test unit with a know good interconnect cable or test the interconnect cable for continuity. Replace interconnect cable if necessary.
  2. Disconnect the interconnect cable from the CSAFE connector and attach to the proper position on the upper PCA.3.
  3. Replace the upper and lower software of the 5.17 elliptical with the most current versions.4.
  4. If one of the PCAs is found to have software version 1.01, replace it with the most current software version.
  5. Disconnect all components from the upper and lower PCA leaving the data cable connecting between the upper and lower PCAs and the AC power going to the lower PCA. If the unit shows any error other than the error 3x, reconnect components one at a time. Reset power between each newly connected component until the error 3x reappears. Whichever component was last connected when the error 3x reappears, is the cause for the error. Replace the faulty component.
  6. Test unit with a known good lower PCA. Replace the lower PCA if necessary.
  7. Test unit with a known good upper PCA. Replace the upper PCA if necessary.
Precor Error Code 30 31 32 33
Feb 19, 2012 | Precor EFX 546i Elliptical Version 4
Whenever I use our eliptical precor efx, as soon as the elevation starts it says error 45
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Aug 10, 2010 | Precor EFX 546i Elliptical Version 4
What is error 50 on the precor efx546
Error 50, Too Much Brake (Magnet) Current
The problem maybe lower board related or improper signal is being translated Call Precor @ 800-347-4404
May 11, 2010 | Precor EFX 546i Elliptical Version 4
Precor uses the same error codes for all of their units. Error code 50 is for excessive brake (eddy current magnet) current.
Mar 19, 2010 | Precor EFX 546i Elliptical Version 4
Error message "key depressed" and no resistance on elliptical.
you will need a keypad and overlay call National Gym Supply @ 1-800 496-7278 they will need M & S #
Feb 06, 2010 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
358 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Jose Pino
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
