Question about Frigidaire GLTF2940ES Front Load Washer
Error efo on my Gallery series load washer...what is it?
  • 15,935 Answers
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
I am getting a EFO then E10 error message after I start a load of clothes...which means I have to cancel the load.
E10/EFO error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
Feb 07, 2011 | Frigidaire Affinity ATF7000ES Front Load...
EFO code cameup.
Its not EFO its EF0 .Theremust be some thing blocking the pump .For example socks,underwear etc. The water was not cycling through properly. Cleaned it out and everything works fine.Use proper detergent mentioned for your model because even SUD formation can cause this error.
Jun 18, 2010 | Frigidaire Affinity ATF7000E Front Load...
Efo
Hello,the EFO code is a general error that is caused because of 2 things:
1.Use of too much soap can be one of the cause of the error. to clear it run the machine through a quick cycle or normal cycle but without using the soap which will drain out the excess soap.
2. The other reason could be that the drain pipe is clogged , to clear it you can remove the back cover of the pump an remove the hose. Inspect them and clean them if nay obstruction.
Thanks
Jun 02, 2010 | Frigidaire ATF6000ES Front Load Washer
E10 error and Efo error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!
Nov 24, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
EFO, E10 error Message
Feb 09, 2009 | Frigidaire GLTF2940E Front Load Washer
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Flashing EFO error code
spoke with electrolux and they tell me that it is over sudsing problem. The washer must use HE detergent or use only a the lowest amount on the cup.
Jul 19, 2008 | Frigidaire GLTF2940ES Front Load Washer
Front loading washer
I don't see either of those error codes in the frigidaire technical data for this model. You can look here:
http://www.frigidaire.com/support/ResultsPage.asp?strModel=atf6000es&User=&Search=Search
I've heard EFO has to do with oversudsing so if you're using HE soap use less, if you're not you should switch.
Nov 03, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
279 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
