Question about Hamilton Beach Water Cooler with Storage Cabinet
Not cooling hi! my water is room temp. opened the back panel and all looks well, however facing the back, the right fan does not spin and by hand is very tight. the left fan works great when on cool, but no cold water. yikes! any suggestions
  • 1 more comment
  • TheGooseman Apr 29, 2008
    My water cooler does not cool. no noise just not cooling. If lacking freon. how do I recharge? any manuals or sites to show how?
  • Anonymous Jun 07, 2008
    Hamilton Beach water cooler one fan does not spin
  • Sweet dick w Jun 07, 2008
    water is luke warm and one of the fans is not spinning
    Scholar:
  • 186 Answers
First check to see if compressor is running. If compressor is running and no cool, then you might have a loss of freon in the system. If it's not running, it might be electrical or a sensor telling it not to turn on. Let it sit unplugged for an hour to see if it can reset.
Grease most likely dried up on one cooling motor. If the motor hasn't burned up, you can try to re-oil the motor. Sometimes they have an oil slot on back, then spin by hand until it becomes free. Be careful not to get your hand caught in the blade when running.
Good Luck and Hope you fix it!
Posted on Apr 23, 2008
Why would the engine temperature remain in the normal range for a couple of hours and then overheats when idling?
Check to make sure both of the electric fans are working. Your car has two cooling fans. As the engine begins to warm up one of the fans will come on. When the engine gets near or above normal temp the other fan will cut on. When you are driving, there is enough air moving through the radiator to keep the engine within normal range. When the car is stopped the fans are needed to draw enough air through the radiator. When the engine is hot and running, open the hood and look to see if both fans are turning. Keep your hands away. Just look don't touch. If neither fan is spinning, or if only one is spinning, you probably need to install a new fan assembly. But check for blown fuses or relays. Have someone check to make sure power is being sent to the fans when they should be spinning.
Jul 27, 2014 | 2006 Dodge Charger
We have a Samsung FR323TEDBSR french door refrigerator that is becoming very noisy
It sound like the fan motor is going bad. They will spin fine when spun by hand but will start to rattle or squeal when running. if it is the model I think you have the entire panel is replaced as a complete unit. This is not hard to replace. It looks like you have already had the panel out. It just has a couple wire to unclip. and clip the new one in.
May 15, 2014 | Samsung Refrigerators
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
I have an ER 1F. I had this problem and took 6 months with LG to fix it. When they couldn't fix it they gave me my money back and said keep the frig. So I bought another and this sits in my garage. I...
1. yes. Open ice room door (back side of left hand refrig door) and turn toggle switch on icemaker to OFF. 2. yes. Do step 1 and connect water to refrig. 3. ER IF (Error Ice room Fan) may still come up. If it does and you don't like it, you could probably avoid that by removing the fan blade from the ice room fan, located in the freezer section, behind the back wall, upper left hand corner. The error code pops up when the electronic board does not see a feedback signal from the ice room fan. Removing the fan blade should allow the motor to run, thus sending the feedback signal to the board, preventing the code from appearing.
Mar 21, 2011 | LG LFX23961ST Stainless Steel Bottom...
I have an IBM x346 eserver that has run well for years. The fans are now very load (whirling noise). I typically only hear this noise when the room temp is high, but this server is in a cool room with no...
It sound like the CPU fan or server case fan/s or power supply fan bearings are worn.
To determine which fan/s is faulty open the computer case and stop each fan from spinning, one at a time to determine the noisy fan. Once you have identified the noisy fan then replace that fan.
Feb 07, 2011 | IBM xSeries 346 Server
I have 2003 grand cherokee with 140000 miles that overheats at idle. as soon as i start moving again, the temp goes back to normal.
You have two fan's on your truck, 1 is a fan clutch runs with the drive belt, 2 elec fan motor, with test light and engine running at normal temp, just a little bit above 1/2 way on your temp gauge check voltage at elec. cooling fan harness if you have voltage at one of the two wire's and fan don't turn on, bad cooling fan motor, on the fan clutch after you check voltage at elec. fan motor turn engine off, with your hand spin drive belt fan if it spin's freely bad fan clutch, replace it.Also check cooling level.Hope this was very helpful
Jan 21, 2010 | 2006 Jeep Commander
Bottom cools and top cools but dose not freeze . Do not heart fan when frezzer is opened.
you do not hear the fan ? your evaporator fan is not working - shut off everything and remove freezer panel look for any excess ice or frust blocking the fan - if everything is clear try spinning the fan blades with your hands, is there any resistence or it spins freely ? Put back cover and turn it on - if fan fails to spin then you have to get it serviced and change the evap fan motor assembly or check the control board.
your unit won't cool if the fan is not working or working erratically.
Sep 24, 2009 | Hotpoint HSS25GFP Side by Side...
Not cooling
disconnect power ...remove lower back panel ...... remove fan and replace.... used appliance shops are a good place for free or cheap fans
I have done this many times on my rental properties
ed
Oct 20, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Relay clicking, not cooling either side
First of all Give me model# and Serial#.
you will most likely have to replace main control board and evaporator fan motor. They have had a service bulletin out on this problem.
Jan 17, 2008 | Hotpoint HSS25GFP Side by Side...
Hamilton Beach Water Cooler with Storage Cabinet Logo
142 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
Dan Webster
Dan Webster
Jim Goldsmith
Jim Goldsmith
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
