Question about Ingersoll Rand - Rand 2 - hp 24 - gallon Garagemate Compressor
When the motor comes on, turns the compressor a few turns, bogs down, triggers the breaker switch.
  • 4 Answers
Either the wiring is insuffcient guage for the load or the motor starter capacitor is bad. If it just started doing this and otherwise ran fine before, replace the capacitor and it will most likely fix the issue.
Posted on Aug 02, 2010
Milwaukee 18volt cordless drill pull trigger motor bogs. Pull trigger motor speeds up and bogs down again, could it be bad switch or motor?
Most likely it is either dirt or a burned spot on the armature of the motor. I would try blasting it with air to see if you can clean it out. If that doesn't work then it probably needs to be torn down to either clean it or replace whatever is damaged.
Nov 02, 2015 | Milwaukee Drills
Why does the machines cct breaker trip on a simoniz S2000 XE02 pressure washer
It could trip for a number of reasons. If you turn it on and nothing happens for a few seconds or instantly trips the motor is overloaded or burned up or a motor capacitor is bad. If the machine turns on and sprays if you hold the trigger open while you turn it on and then trips when you let go of the trigger you probably have a problem with the cut off switch . The circuit breaker might be too small for the load of your machine. The extension cord might be too light duty and causing the breaker to trip.
Jun 26, 2014 | Coleman Powermate DuraBuilt 1400 PSI...
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oct 22, 2013 | Campbell Hausfeld VT6290 2.0 HP 20 Gallon...
Trigger siwtch spark cause electric short circuits
short in the ignition switch or loose wire at the ignition switch. if trigger switch is the key ignition switch you referring to.
Sep 02, 2012 | Cars & Trucks
Compressor will not refill itself with air during use
IT SOUNDS LIKE THE PRESSURE SWITCH ISNT WORKING CORRECTLY. IT SHOULD CUT IT OFF AT DESIRED PRESSURE AND RESTART IT AT CUT IN PRESSURE. YOUR BOG DOWN PROBLEM ON RESTART IS PROBABLY DROPCORD TOO SMALL OR THE COMPRESSOR IS NOT UNLOADING WHEN IT SHUTS OFF WHICH IS ALSO CONTROLLED BY THE PRESSURE SWITCH. WHEN YOUR COMPRESSOR SHUTS DOWN YOU SHOULD HEAR A HISS FOR A FEW SECONDS. THE SWITCH IS DRAINING THE AIR FROM THE TOP OF THE PISTON SO IT DOESNT START UNDER A LOAD THE NEXT TIME. HOPE THIS HELPS. JODY
Apr 11, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
When my compressor tries to kick back on, it bogs down and trips an internal breaker switch.
When finding a home for any compressor you need to take a few things into consideration. Extention leeds can create a voltage drop. for a standard compressor you will need at least a 40 amp trip switch at fuse board the draw of first start up could be a higher rating than your current breaker
Mar 12, 2009 | Air Tools & Compressors
T49 True Refrigerator turns off by itself, breaker not triggered
There are several things that could shut off your unit. If you are shutting the breaker off for longer than a few minutes, the compressor might be cooling off during that time, thus allowing it to turn back on. It also might be shutting off because of the pressure switches located on the refrigerant lines. Please let me know if you need anymore information.
Nov 24, 2008 | True T-49 Side by Side Refrigerator...
Ingersoll Rand - Rand 2 - hp 24 - gallon Garagemate Compressor Logo
108 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
