Question about Pioneer DEH-P4800MP CD Player
Trying to set clock
When I press the function button, held it down nothing happened. Now what?
To set the clock, do the following:
1. Press and hold the MULTI-CONTROL button for 2 seconds
2. Rotate MULTI-CONTROL button until display reads CLOCK.
3. Push MULTI-CONTROL button up or down to adjust hour and minutes.
4. Press ESCAPE or SOURCE button to exit
Posted on Jun 15, 2008
How to set clock on GE range
press and hold the timer key for 5-10 seconds see if it flash;s if so use the arrows for hour and min, comment back with all the setting/buttons it has other than temp for individual ranges :)
Hope this helps ya!
May 19, 2009 | General Electric Stove/Oven/Range Chrome...
Coffee maker, bought used cuisinart grind &brew, how do i use it?
Setting the Clock:
When the coffeemaker is plugged in, 12:00 will
flash continuously until you set the time.
Entering “Time Set” Mode:
To set the time, hold down either the “Hours”
or “Minutes” button until the clock stops flashing
and begins to count up (about 2 seconds).
You are now in the “Time Set” mode and can
operate either button to achieve the desired
setting. The buttons can be held down to scroll
through the digits, or pressed and released
lightly to advance one digit at a time.
When scrolling, the numbers will advance
slowly at first and then speed up to the rate
of about three per second. When the number
displayed approaches the desired setting,
release the button and press repeatedly to
advance one digit at a time. Be careful to
make sure that the PM indicator is on if a
PM time is desired.
Exiting “Time Set” Mode:
The “Time Set” mode can be exited in
one of two ways:
1. Press any button besides the “Hours” or
“Minutes” button. This will exit the “Time Set”
and activate the selected function.
2. Do nothing. If neither the “Hours” nor
“Minutes” button is pressed for a period
of five seconds, the “Time Set” mode will
be exited.
Mar 21, 2009 | Cuisinart Grind and Brew, 10 cup, black
Setting the clock
hold source button down to turn the units power off
once the unit is off hold down the F (function button) till you hear a beep from the unit once this has beeped press the F(function) button 2 or 3 times the clock should display flashing numbers
once you have this press the buttons to skip the songs to the hr once hrs are set press F (function) button one more time to select minute settings after this has been set..........hold down the source button till the unit powers back on and clock will be set on this unit
hope i was able to help you
have a great day
Mar 04, 2009 | Pioneer DEH-P2000 CD Player
Setting the Time
First, turn the Function Knob (bottom-left of the Control Panel) to “Clock”.
Hours: Press and hold the “HR” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press(pulse) the button to advance one digit at a time.
Note: When the number passes 12, the PM light will be displayed on the LCD.
Minutes: Press and hold the “MIN” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press (pulse) the button to advance one digit at a time.
To finish setting time, turn the Function to any setting other than "Clock", or simply wait until the numbers stop blinking.
Jul 26, 2008 | Cuisinart DCC-1200 Coffee Maker
Setting the clock
Remove the plug from the socket for a few minutes. Then plug it back. Does the clock control blicking? look at the pictures on the control as a whole.
Do you see anything like a table clock? press it once, then press the numeric pad or up and down arrow button depending on the model you have. press enter or start if set correctly.
Jul 24, 2008 | KitchenAid KGST307 Gas Kitchen Range
Keeps flashing 12:00
Hi jippers - try this :
1. Setting the Clock
When the coffeemaker is plugged in, 12:00 willappear until you set the time.
To set the time, hold down either the “Hours” or“Minutes” button until the clock begins flashing (about 2 seconds). You are now in the “Time Set” mode and can operate either button to achieve the desired setting. The buttons can be held down to scroll through the digits, or
pressed and released lightly to advance one
digit at a time.
slowly at first and then speed up to the rate of about three per second. When the number displayed approaches the desired setting,release the button and press repeatedly to advance one digit at a time. Be careful to make sure that the PM indicator is on if a PM time is desired.
one of two ways:
be exited.
If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a nice day.
Jeff
May 08, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Pioneer DEH 225 car radio instructio booklet
Actually, there a re a bunch of hits when you Google it.
Here's the answer I found straight from Pioneer:
If your car CD player is a 2006 model or newer:
  • With the ignition on and radio OFF,
  • Press and hold the MULTI-CONTROL button for 2 seconds
  • Rotate MULTI-CONTROL button until display reads CLOCK.
  • Push MULTI-CONTROL button up or down to adjust hour and minutes.
  • Press ESCAPE or SOURCE button to exit
If your car CD player is newer than 2000 but older than 2006:
  • With the ignition on and radio OFF, press and hold the FUNCTION button, until the display pops up, then release the button.
  • (If you do not have a function button, use the AUDIO button instead).
  • Press the FUNCTION button again until the clock shows on the display.
  • Press the UP and DOWN buttons to adjust the hours.
  • Press the LEFT and RIGHT arrows to move to the minutes.
  • Press the UP and DOWN to adjust the minutes.
    When you've completed all the steps, just press the SOURCE button to exit
If your car CD player is 1999 or older:
  • While holding down the CLOCK button, press the number preset button to set the hour.
  • While holding down the CLOCK button, press the number 2 preset button to set the minutes.
  • Pressing the respective buttons consecutively or continuously will advance the hour and minute.
For further assistance please consult your user manual.
Here are some other answers from around the web:
Hold down the source button till the unit switches off. Press thefunction button until it says clock. Use the tuner/volume controls tochange the time. Left/right switches between hour and minute. Up/downchanges the actual numbers.The website I'm including has all the old manuals on it if this doesnot work for you. Problem is, you may not know your model # so willhave to click through the links till you see a pic of one that lookslike yours. Hope this helps. I'm stoked that my clock is finally right!
turn the radio OFF with the car ON
then its easy to set the clock.
Most folks try to figure it out with the radio on
and it cant be done with the radio on,
Turn it off. Hold down "func" or "function" until something happens.
Then press the arrow keys still something else happens. When you're done, press "func" or "function" till nothing happens. Turn it on.
Dec 03, 2007 | Pioneer DEH-225 CD Changer
Time setting
Make sure unit is off by pressing and holding the 'Source' button. Wait 3 seconds, and then press and hold the 'Source' button. Do Not Release the button! A display reading "Initial" will show. Then use the arrow buttons surrounding the 'Source' to set clock. The 'Function' button isn't involved, dispite what the manuel states.
Nov 28, 2007 | Pioneer DEH-P3900MP CD Player
Time change on Pioneer car radio
Turn the raido/cd player off. Hit the clock button. Time will display. Press and hold down the audio button for 4 seconds. Use the arrow keys to change time. Press and hold the audio key when finished until the time is done flashing.
Nov 07, 2007 | Pioneer KEH-P2030 Cassette Player
Pioneer DEH-P4800MP - Can not get into INITIAL mode to change settings
Actually, TRY powering OFF the unit, and release the volume button. Then, press and hold ONLY THE VOLUME BUTTON, until the initial settings appear. Pioneer really needs to get their act together on this issue. I have read all over that MANY people have had this issue, and the website is just a repeat of their lame printed manual.
Hope this helps. In review:
From OFF, press and hold ONLY THE VOLUME BUTTON. The initial settings shall appear at this point after about three seconds...
I just read these instructions, and while trying it, I found that my FUNCTION KEY had ABSOLUTELY NO FUNCTION IN THIS.
Jan 08, 2007 | Pioneer DEH-P4800MP CD Player
Pioneer DEH-P4800MP CD Player Logo
61 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
