Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Pool is green, is there anyway to get it back without draining?
  • 297 Answers
This is a complicated answer and I am not the greatest typist so I copied and pasted my answer to someone else with your same problem here it is
So many peolpe are led to believe that using a salt system takes away the need of other chemicals
This couldn't be further from the truth A salt system just makes it so that you do not have to physicaly ad liquid chlorine or float tablets
First of all lets get a little educated in pool maintainence 101 and then I will address your problem ( First problem was buying an Intex product ) but I will cover that too
You can not just blindly ad salt to the system
you need to get a salt test kit that reads in #'s not color
You need to get the water to as close to 3000ppm as possible
Any lower than 2700ppm and you can trigger low salt alarm, not to mention not generating enough chlorine
Any higher than 3500 and you can go cloudy, trigger high salt alarm and you could go cloudy
Now for the intex curse
not a single pump/filter is sufficient with the pools they come with
They are to small
A pool needs to be turned over at least 3-4 times in a cycle 24 hours
I do not know your gl or pump size so I will use generic #'s
If you have a 5000gl pool and a 1500gl pump thats 10 1/2 hours of filtering at the minimum
Use your #'s and figure out what you need to be doing
You want to start by getting your salt right this is crucial What it says in the manuals is just a starting point the fine tuning is up to you
Lets now side track and I will tell you how to cure your problem.
This is time consuming but will give you the best results
Blast out your paper cartridge with the water hose now ad 1 gallon ofliquid chlorine
Filter only for 24 hours now brush your pool with a pool brush not the bristles under your vaccum not enough of them to do any good
now clean the filter again and run for a few hours until you see things settle down
Vaccum and clean the filter and start over again
Check your chlorine if it is normal or low ad another 1/2 if it is super high then leave the chlorine step out
Once you are clear again or close to it Ad a non foaming algecide and also ad chlorine stabilizer this is a chemical that you put in a nylon sock and float it behind the ladder this will help hold the chlorine
Once your chlorine level is at the point you can swimm again you should get your best swimmer to get in with a tooth brush and clean the over flaps in the seems that are on the bottom and where the sides connect to the floor
This should do it
lets look at one more thing
Chlorine generation
There may be night that you need to run it 12 hours for chlorine and other nights 5 or so
It all depends on many factors
sun,heat,number of swimmers, sun tan oil and so on
The biggest thing you can do wrong is to not use the pool If it is not being used every day you should brush sides and floor every 3 days or so. The pump is not strong enough to circulate the water properly
One more thing that I do and I have not changed my filters in this being my 3rd season
I have 2 one is always drying
Start with a dry filter and have the other clean and drying
Change them every couple of days.
Never try to use a wet filter it does not work like a dry one
Dont ask why it is just one of those mysteries
Also periodicaly take the hose off the front of the motor your inlet hose this can build up hair and debris that gets in from skimming
Good Luck
Don't forget to rate this
Posted on Jul 27, 2010
Can I use pool salt in my summer escapes pool?
if you have a salt system add salt but you have to shock pool to get it clear
Jun 09, 2014 | Intex Automatic Salt Water System for ...
My pool is nasty green...waiting for intex saltwater unit to arrive. Do I need to drain pool before and put clean water in before I begin running this new pump?
I would start with a fresh clean pool if it's that nasty green!!! Drain and scrub all algae..
Did you already buy your salt?? Remember.. you will need to add your salt and run the pump without the chlorinator for 24 hrs to properly dissolve the salt.. If your not sure how much salt to buy, post again how many gallons your pool is and how much salt will you need and you should get an answer from one of us... Good luck....
Aug 20, 2011 | Intex Automatic Salt Water System for ...
The water in the electrolytic cell is green? Do I need to clean it?
I assume from your comment about having green water in you electrolytic cell that maybe you don't have it connected to a pool yet or the pool water is green also. Anyway, if you are just starting your system and there is green water in the electrolyic cell then pore it out and when you place it into operation the pool water will clean it out. If the electrolyic cell is working the most overlooked cause for green water besides not having salt in the pool is it has no stabilizer in it. This is a chemical that has an affinity for chlorine ions and if it is not there the chlorine can be disipated in a few hours when the sun hits it. Another name for it is Cyanuric Acid. It can be purchased in granular form at many pool supply stores or in a liquid form at Leslies. In order to get your pool blue you need to have the chemistry checked at a pool store or with a test kit (either liquid or strips). Don't buy everything a pool supply tells you to buy but start out with chemistry test strips, vinyl safe shock, stabilizer and salt. The pool store should be able to help you determine the dose. The following is what I would do:
1. Make sure salt is at the recommended concentration.
2. Shock the pool to recommended dose to start killing the algae.
3. Place the recomended dose of stabilizer in the pool.
4. Make sure pump and filter are working properly.
5. Check the pool chemistry on a daily basis until it is ready for swimming (or for at least 1 week).
6. Check the chemistry on a weekly basis and clean the pool and equipment according to the pool instructions.
Smile, you are a pool manager.
Jul 04, 2011 | Intex Automatic Salt Water System for ...
I am getting a error code of 92 on my intex swg. I have put 4 - 40 lb bags into a 15 x 48 pool and brushed the bottom to distribute the salt evenly. I left the pump on for 24 hrs and then set the swg for...
I installed a new Intex ECO 8110 unit on my 15' above ground, steel sided pool. After about 10 hours of use I had the "code 92' high salt alert that shut the system down. I knew that my salinity wasn't high because the local Pinch A Penny pool store does free water analysis and i was given the okay just a week prior. We had also received a bit of rain in the interim so I knew that the alert was false.
Here is how I fixed the problem (so far).
1. Turn your unit off.
2. Disconnect the power cord from the outlet and wait for 2 minutes.
3. Unscrew the retaining nut at the electro-cell connector and unplug the connection.
4. Rotate the plug 180 degrees to reverse the polarity of the plug and re-connect to the electro-cell.
5. Reconnect the power cord to your receptacle.
6. Turn the unit on, wait for the green light to burn steady.
7. Monitor for the next 5-10 minutes.
My unit has worked flawlessly for 3 hours. If i receive another "code 92" alert i will repeat the procedure which will result in bringing the unit back to its original polarity.
Jul 01, 2011 | Intex Automatic Salt Water System for ...
My Hayward pool sweep gets stuck when it goes over the drain at the bottom of the pool
It could be worn shoes on your pool cleaner causing the problem, but it is most likely just that you need to get a ring drain cover to cover your anti-vortex drain. It creates a smoother surface and is designed specifically to work with in ground automatic pool cleaners that are getting stuck on the drain.
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
Mar 19, 2011 | Hayward Navigator Pool Cleaner
Navigator sitcks on pool drain and won't move off
You will need to shut your drain down completely. If you get suction through the drain and the cleaner they will stick together. With the cleaner the drain is redundent anyway.
Sep 27, 2010 | Hayward Navigator Pool Cleaner
Dial a flow question
Ok the first on the PSV valve. the 1/2 position should really be 1+2. You have two linlets to your pump. One from the skimmer and one from the main drain in the floor of the pool. When you select port 1 it will be one or the other perhaps 1 would be skimmer and 2 would main drain. You can select one and see if the flow stops in the skimmer. That will tell you which is which, depends on how it was plumbed. Position 1+2 combines the two flows. I normally select both, If my pool gets a lot of grass and leaves, I select skimmer only or when I vacuum. I select main drain only when there is more debris at the bottom. OK recirc is only recirculating within the piping system bypassing the filter. You can dowload a complete manual of your filter and components from www.haywardnet.com. Green water: Ok your chemicals are right? Free Chlorine, total chlorine? hardness, calcium, pH, alkalinity? Well most pool companies want you to buy some algaecide and that can't hurt, but I'd shock your pool if it's dark green I'd put it 4-6 gallons of liquid chlorine, if its light green 2-4 gallons. This is when I'd use recirculate. Allow this to mix without filtering for a couple of hours. Turn the pump off and allow to set overnight. In the morning you should have much clearer water, with green slime sitting on the bottom. Vacuum this to waste very gently so as not to remix algee.IF this doesn't work you'll need som floculant and repeat the opeation folling the directions on the floculant Restart filter, keep chlorine level high above 5-10ppm for a day or two and keep filtering. If it is still cloudy now,add some filter aid. In hot weather, don't let that free level go below 4ppm. Don't allow anyone to swim while chlorene level is high. Be sure to us test strips that indicate free and total chlorine.
Jul 21, 2010 | Hayward SAND FILTER, PRO SERIES
After I vacuum the pool, backwash it and then turn the filter system back on it blows in a lot of green water back into the pool. What should I do?
1st Green water is algee. Kill the algee in the pool. 2nd when you're finished backwashing the filter. Stop pump and move valve handle to rinse position. Then restart pump. Run in rinse mode until glass is clear. Then stop pump again, and move lever to filter position. When you're backwashing, you're reversing the flow of the water through the filter. When you switch directly back to filter, anything left loose in the filter flows back to the pool. When you select rinse, it reverses the flow back to normal, but keeps the water going to the waste outlet until clear, that way that green puff of water will go out the drain. You can get complete manuals from www.haywardnet.com
Jul 20, 2010 | Hayward SAND FILTER, PRO SERIES
My salt is high, does this cause pool water to turn green? why is my pool water green?
t is too high, the generator shuts off so no chlorine is being created; hence the green pool. Drain water and add fresh until the salt level is diluted back to the range your generator manufacturer suggests and your chlorine will return. In the mean time, shock the pool to get rid of the algae and the generator should be able to maintain it from there.
Jun 15, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
260 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
