Fuse burn out
Everytime i turn on the ac the fuse in the circut board blows out. the fan blows fine so does the heat. i checked the wires for a short but it checked ok.
    Scholar:
  • 149 Answers
Thermostat section for cooling could be faulty if its electronic some short is possible on the electronic board
Posted on Apr 23, 2008
I have a 1999 mazda b2500 truck, everytime i use the a/c or heat i blow a fuse (7.5mini #10 fuse). Thought it was turn signal as they were on same fuse, replaced switch and relay, still blowing fuses, also...
Disconnect the electrical connector to the AC compressor clutch and try again. If the fuse doesn't blow, then you've got a shorted AC clutch coil.
Nov 24, 2017 | Cars & Trucks
Fan motor
chk the wiring inside any short circute or burned one.
Jul 14, 2008 | Maytag M7DH45B2A Dehumidifier
My technics integrated amplifier su-v85a blows the fuse everytime i turn it on.what can be the problem?
Fuses blow when there is an overload. Often caused by a short-circuted semi-conductor. I would go straight to the main amp board and suspect the devices on the heat sink.
Jan 21, 2013 | Audio Players & Recorders
Why does my fuse keep blowing
If its the correct size fuse you have a short causing the fuse to blow. if its a fuse to say the a/c compressor, the compressor is pulling over the fuse size and causing it to blow.
Aug 17, 2012 | 2002 Saturn L-Series
Fuse blow each time I turn on air check for
disconnect the thernostat wires from the control board. Put a jumper wire between R & G put door back on and turn on power. Blower motor
should run, if it blows the fuse then you have a direct short between R &
G at the board. Do this with R and W(heat) and R & Y(cool).
By disconnecting the thermostat wires and reinserting them make sure that they do not touch when inserted into each terminal. If it still blows
that little 3amp fuse when jumpering between each sequence as mentioned above, then I think your board is bad. When Jumpering out the Y terminal you will have to have the AC wires still hooked up. If it
blows the fuse in that sequence. Disconnect the wires out at the condensor.
You mat have a bad contactor at the outdoor unit.
Jul 16, 2010 | Goodman GMS90703BXA Heater
Transformer and circuit board blown on Nordyne AC this happened suddenly when the a/c has been running fine, also it blows the 3 amp fuse on the circuit board, I replaced with a 10 amp fuse and it ran fine...
Lol. I'm trying to find a good way to put this and the best thing I can think of is this... dental floss is skinny enough to squeeze between your teeth, if you tri
Sep 24, 2017 | Heating & Cooling
Why does the fuse blow everytime i turn on my heat or air conditioner.
Fuse will blow only if excess current flows through it than its capacity, Get the a/c wiring, fan checked for any short circuits, or may be the replaced fuse is a low ampere fuse.
Oct 08, 2009 | 1999 Mitsubishi Galant
MY SAMSUNG MW6574W OVEN FUSE BLOWS AFTER 4-5 MINS OF REHEATING-NO SMELL OF BURNING -EVERYTHING ELSE WORKS FINE- NO LOOSE WIRING-ALL BULBS WORK FINE TOO- THE FOOD HEATS UP FINE EXCEPT THAT THE FUSE BLO
the insulation of the wiring has detiorated and with temperatue rising it further deteriorates. thus increasing the current consumption and blowing the fuse
May 21, 2009 | Samsung MW6575G/MW6574W Microwave Oven
We have a problem with our 2000 stratus fuse, everytime we push on he brake pedal the fuse blows? What could be the problem?
It sounds like you have whats called "a short to ground" Breaks operate on whats called an open circut, only when you ppress the pedal does it allow the eectricity to flow hence lighting the rear break hights. You have a pinch wire which is grounding the system. Each time you press the pedal it sends the current to that ground shorting the circut and blowing the fuse. Trace the wires in the trunk as best you can and look for any damaged wires(oinched ,stripped, also check the break light socket .
Apr 28, 2009 | Dodge Stratus Cars & Trucks
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
