Pentair water softener leaks water; carpet soaked all around softener - how to fix? dont have owners manual already installed in house when I bought
  • Anonymous Nov 18, 2008
    same problem here. did you ever get a real fix?
  • eric bosman
    eric bosman May 11, 2010
    where does it leak. At the valve?
  • 101 Answers
Open the top and reseat the hole,if not replace the hole. hop this could help you.
Posted on Apr 23, 2008
I have a Pentair water softener but have no idea how much salt I have put in.
You didn't state what model number. But Pentair manuals can be found at this website.
Pentair Fleck User Manuals Water Softeners Filters
If you find this helpful, please mark it as such! Thank you!
Dec 06, 2016 | Dishwashers
Need owner's manual or set-up instruction manual for Pentaier Structural Water Softener - Model #CH30127
That is only the softener tank. We need to know what water softener valve you are using on the tank itself for further assistance.
RJ
Aug 19, 2013 | Pentair 14 x 65 Structural 30785 Poly...
Leaking Culligan Water Softener at neck of tank, pipes might have gotten hitr since they are in the garage?Any idea what the troubles could be? If anyone has a manual, I would like some assistance.
I would suggest by-passing the system if the leak is substantial. Also make sure the leak is not coming from the main piston. Frequently leaks occur here, water runs down and collects around the top of tank before running down the side. Take the cover off, run the system through a manual regeneration and observe for any leaks. If the tank was hit it is most likely the leak is coming from connections between control and softener by-pass valve. If leak is coming from the tank and valve connection you will need to take the valve off to see if there is a crack at the tank threads. If so tank needs to be replaced. Here is a link for Culligan site that will have the manual for your machine.
http://www.culligan.com/en/service-and-maintenance/customer-support/owners-guide/
RJ
Sep 05, 2011 | Culligan 34" Whole House Water Filter...
I have culligan house water softner. after i changed my hot water heater my softner stopped working. I dont have a manual to check. any suggestions?
Unless the softener was bypassed when the water heater went in, installing a water heater has no bearing on the softener working or not. Is it unplugged?
RJ
Aug 27, 2010 | Culligan 34" Whole House Water Filter...
TDB662RBR0 dishwasher leaks. Tub/door gasket is stiff and split. What is involved in replacing the gasket?
not much at all is involved, the seals usually are pressed into a groove around the edge, pull old one out press new one in, just dont pull to sretch it as you put in the new one
Oct 28, 2009 | Tappan MDB531RF Dishwasher
Water softener seems to be draining all the time
http://www.puritecwatersofteners.com/documentation/Hydrotech_5600MI_manual.pdf
I'm pretty sure this is the manual for your unit. It might not be exactly like the one you have but at least could give you info for it. This is something you might have to contact the manufacture for. Hope this helps!!
Mar 31, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Floor on passenger side gets wet when running air conditioner
I have a 2006 Fusion with the same issue and I fixed it for less than $2. There is a drain tube that goes from the passenger floor board out through the firewall to allow water to drain under the vehicle. However, water can travel along the underside and seep back into the vehicle. I went to a hardware store and bought a few inches of 5/8" tubing. I simply slipped this onto the drain and the water now flows down the tube and safely away from the interior of the car. Been dry ever since.
Jun 03, 2008 | 2004 Ford Taurus
Washing Machines Logo
506 people viewed this question
Top Washing Machines Experts
