Question about D-Link DGS-2208 8-Port Gigabit Ethernet Switch (DGS2208)
Dgs-2208 can't get switch to work when coming from another dgs-2208, trying to use 2
  • Anonymous Apr 22, 2009
    I have the same problem - not sure why it is not working...
    Also have trouble with switch recognizing computers after powering up from hibernation mode...
    New Friend:
  • 50 Answers
What are you trying to do?
Aloha
Bob
Posted on Apr 24, 2008
How do i connect my 8ports hup
What are you trying to do with this? If you're trying to share an internet connection then this won't work.. you'll need a router instead. If you're trying to set up a home network however, all you should need to do is have your switch powered on and then start connecting devices. Afterwards you may have to change some network settings depending on your operating system.
Nov 16, 2010 | D-Link DGS-2208 8-Port Gigabit Ethernet...
I interconnect a D-Link DES-10160 with D-Link Gigabit Switch DGS-1024D network and my network becomes slow
connect only DGS -1024D to your network....it will be faster...
because DGS supports 10/100/1000 speed.... but DES supports only 10/100 speed...
connect DGS directly to your network and work with that... if you wish to extend the number of ports then connect the DES to one of the ports of DGS
and dont connect DGS to one of the ports of DES
May 10, 2010 | D-Link DES-1024D Express EtherNetwork...
D-Link DGS-2208 only works through Hub uplink but not router?
i think it it ehternet cable problem.
when u connect switch to swith it is twisted pair but when u connect router to switch then straight.
Dec 31, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
Connection dropping every 2 hours and router resets
For these commands, Start, Run, CMD to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
If that doesn't get the job done after a reboot, set it to automatic IP addresses, reboot, then post this:
Start, Run, CMD to open a command prompt:
IPCONFIG /ALL
Right click in the command window and choose Select All, then hit Enter.
Paste the results in a message here.
Jun 25, 2008 | 2wire 2700HG-B Router (2700HGB)
Dlink dgs 2208 switch
pls check your connection between the switch and the router,dsl,access point.
2.make sure the gateway router is receiving good signals
Apr 12, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
Won't allow connection to router
Since each of these devices is rated for 1000Mb/s, everything should be compatible. Make sure the NIC driver is up-to-date on your computer....and use automatic settings for speed and duplex wherever you have the option of setting it. The only other thing I can think of is to try a "crossover" cable between the router and switch...although this function is usually handled automatically in most modern interfaces.
Jan 05, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
D-Link DGS-2208 8-Port Gigabit Ethernet Switch (DGS2208) Logo
283 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
