Question about Cameras
How do I hook a video camera up to a television?
    Problem Solver:
  • 9 Answers
Thee shoiuld be an output on your camera usualy a special phono plug or RCA connectors, possiblly but not probably a coax connecor. Either of these could be hooked up to you TV. Check the manuual for outputs. Sometines they supply you with a special cable that has 3 RCA male coinnectors on it. That contains your 2 audio channels and a video output. There could be other combinations as well.
BobDE
BobDE
Posted on Apr 23, 2008
HOOK UP VIDIO SURVALENCE CAMERA TO BACK OF TV
The camera output would have to be composite---and if so go to one of the rear audio/video inputs: yellow (composite video) is likely all you would need unless the camera has audio as well (go to red or white on same input).
Jun 02, 2012 | Hitachi 43UWX10B 43" Rear Projection...
How to hook up digital camera to tv
if your camera has a video and audio cable then it is possible,just connect the one part to your camera and the other part to the audio and video output of your tv and the switch your tv to AV, if it does not display interchange the cable you connected to the tv.
Feb 24, 2010 | LG 32LG30 32 in. LCD HDTV
How can I hook this cam up to my Television?
For this camera you will need to find in your equipment (or purchase) a "stereo video cable "
This cord features a 1/8th (male) headset jack on one end and 3 male RCA jacks on the other. (yellow/red/white).
Plug the 1/8th jack into the camera's AV input and the RCA plugs into your TVs RCA port input and select the correct AV input (AV 1, 2, etc)on your tv selector and the camera should play through your tv.
Nov 04, 2009 | Canon ES75 Camcorder
How to see camera video
Depending what type of camers you got you can hook it up to the tv or by a converter cartrige. I did not see what type you got so my answers was based on brand and type here.
Thanks
Jun 26, 2009 | Polaroid TTM-2003 Combo
Security camera hook up
Hi Boybest,
Yes it's possible.
You have several options with your TV. You can use the Video-In from the auxiliary/line in or even though a VCR. The plugs in this case use what are called RCA Jacks. They travel in three's, one yellow, one red and one white. The yellow is the Video.
Any hook up is going to be dependent upon the output from your camera. Security cameras, for the most part output a video signal much the same as a VCR. Some however use RF (Radio Frequency) which requires it to be attached to a cable or antennae jack and then tuned in (usually channel 3 or 4).
If it's a straight NTSC Video signal there should be no problem. A long cord with RCA jacks to the Video-In would do it. Then you could switch the channel to AUX or Line One (which ever your model uses) to get the camera signal.
Computer cameras have a whole different way of doing things. If you run into any snags, comment me back with the make and model of your camera. I'll get you up and running.
BTW, good things come to those who rate. ;-)
Hope this helps.
Mike
Feb 12, 2009 | RCA 20F420T 20" TV
How do I hook up a Sony Handycam Video 8 CCD-TRV41 NTSC to view on television?
the camera should have "a/v"out rca jacks.
yellow is video,other is audio,hook it to your tv or vcr.
YES,you can capture to your computer,but youll need a device with capturing/editing software.
dazzle,is an external adapter,and pinnicle used to sell a package,with an internal pci card,which is capable of importing "analog"(your old 8mm,or from vcr),OR digital(via firewire)if you decide to buy a newer camcorder.
BOTH products come with editing/dvd burning software(which you WILL need)and I can say from experience,pinnicle is easy to learn!!
Dec 16, 2008 | Sony Handycam CCD-TRV41 Camcorder
Hooking mini dvd camera to play through the television
tape needs to be played from camcorder only w/ a/v cables to tv-no other way unless you make dvd on computer first
May 13, 2008 | Video Cameras
I still have my CCD-TRV41 and the manual intack. You will just need a audio/video cable (2-colored or 3-colored) to view your movies.
Aug 29, 2007 | Sony Handycam CCD-TRV418E Camcorder
JWin 2.4 GHz wireless video monitor
As am not conversant with the type set mentioned,I can only suggest u check if the video-out/rec-out connexion has a switch on the remote or manual,check that you connect to vcr line in and set your monitor to view vcr output, good luck.
Jul 30, 2007 | Jwin JVTV2042 Security Monitor w/ Cameras...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
