Keyboard probs advent 9115 laptop
My toddler has slammed down on my keyboard and now i cant type a number 9 without holding down the function key or any letters that have numbers in blue relating to the function key. if i hold down the function key i can type all the letters ok but if not u becomes 4, i - 5, o - 6, etc.
has my function key been damaged and what can i do?
  • de88ie_r Apr 25, 2008
    thank you - so simple and i was really worried something terrible was wrong! good to be able to type again!
  • ggpeking Jul 25, 2008
    where is the num lock on my inspiron 6400 (german keyboard)?
    Problem Solver:
  • 12 Answers
Sounds like your num lock has been toggled on by mistake. Look for a key that says NmLK. It will be in the same color blue. That key may also be the scroll lock key(ScrLk) that should solve your problem.
Thanks
Todd
www.LaptopGuy.com
Posted on Apr 23, 2008
How do I replace the main battery in my Advent 9115 laptop and any suggested supplier?
look for the model number of the battery and look on ebay. watch out for cheap batteries since they won't last long.
Mar 22, 2013 | Advent Computers & Internet
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Jan 29, 2013 | Computers & Internet
Advent 9215 keyboard malfunction
The laptop keyboard will need to be replaced, go to www.ebay.com Type: make and model of computer, refine search to keyboard.
May 20, 2012 | Advent Computers & Internet
Half of my letter keys when i type are numbers???????
You have number lock on "num lock" fine that key on youre keyboard (ussualy top right) and press it. If its colored then press it with function key "fn" left down side of keyboard.
May 02, 2010 | Advent Netbook
My dell laptop types numbers instead of letters on some keys without pressing fn key
HI,
If you Are writing numbers instead of letters when you press the keyboard of your laptop and you must hold down the Function key (Fn) to write normally.
This is due to the fact that the digital lock is activated. To solve this, simply press the Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
Hope This Helps
THANK YOU
Feb 27, 2010 | Dell Vostro 1510 Laptop
WHEN I TYPE A J OR I FOR INSTANCE I GET A NUMBER 1 OR A NUMBER 5 . I WILL NOW TYPE THIS SENTANCE AGAIN WITHOUT HOLDING DOWN CORNER KEY WHICH PREVENTS THIS FROM HAPPENING. ''WHEN 5 TY-E A 1 6R 5 F6R...
Try turning off the Num Lock on your keyboard if it is on. To do this, Press & Hold down the Fn key and find the button that has the NmLk in blue and press it.
Nov 07, 2009 | Advent 4211c Notebook
Keyboard types upper case digits instead of lower
It sounds like you may have turned on the calculator function - Does one of your F keys have a light on - F10 or F11, if so Press Fn and the key that is lit up.
May 21, 2009 | Advent Netbook
Re touchpad behaving oddly!
Debbie, I can't find anything on this that would cause it with a keyboard command. Lets do this; lets roll back the system to the last restore point before your one year old confused us both. LOL....
Click on Start Menu and then select HELP & Support
in the search box type SYSTEM RESTORE
when the options come up look for RUN SYSTEM RESTORE WIZARD and follow the prompts to the day before the issue was created, or the closest date available before the problem.
When the system rolls back we will see if that fixes your problem. (It's not as scary as it sounds)
Let me know if this works for you! //Don
Apr 26, 2008 | Computers & Internet
Function keyboard turned on advent QT5500
Hi
Try this my friend,
Press F12, Num Lock, and FN at the same time.
OR F12 and Num Lock/ Scroll Key.
OR Hold the Ctrl and Fn key down together and press also
the Ins(Num LK) key.
Post me whatever the result is... so we could Fixya the problem.
Feb 03, 2008 | Computers & Internet
Computers & Internet Logo
524 people viewed this question
David Payne
David Payne
