Question about Vacuums
How do i replace the fan blade assembly which are broken in my ureka model the boss thank you lorne
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=540001
Generic problem for all Vacuums
Posted by lmurray1 on Apr 23, 2008
How do i replace the fan blade assembly which are broken in my eureka model the boss
thank you
lorne
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are 2 different models of the boss by Eureka – there is a standard old style upright that the belt that the belt would unscrew from the bottom of the motor and you would have to remove the top of the vacuum cover to remove the main motor and gasket assm, and then the fan has a reverse thread on the plastic fan and you would unscrew the fan after removing the belt pulley. Then you would screw on the new fan, belt pulley, replace the gasket and re-install the motor. If you have a new style with a side mount motor you would remove the top cover, the motor would be in there sideways, un-screw the motor, remove the silver tape around the fan housing and un-screw the fan housing – same as above un-screw the fan from the motor, there is a nut on the end of the fan holding that on – (remember, the fan has a reverse thread) re-install the fan. Then the fan housing, replace the silver tape, and then screw down the motor and replace the top cover, then you can test. As always free to contact your local vacuum dealer in your area in the yellow pages or contact your Eureka factory manufacturer listed below:
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 23, 2008
Very poor suction
Make sure ALL the air passageways are not blocked with any hair, dust balls or other material. If they are ALL clear, then it's probably the fan blade that creates the suction is damaged, maybe a blade or two are broken. It is cheap to buy a new fan blade, but taking the machine apart and replacing the blade would be moderately expensive for a repairman. Maybe you can try to do that yourself. If not, always ask for a complete estimate for the repair, and have it written out on paper before you agree to the work.
Oct 18, 2013 | Dyson Vacuums
Hi My bissell proheat 2x 9500 is making a loud noise when the brushes are moving. I replace both belts and cleaned the brushes. Can you think of anything else it could be.
Hello there,
Try using other brush attachments, as broken bearings in a brush attachment will cause noise. If these troubleshooting techniques do not work, you may need to service the engine.
Remove the filter and bag of the machine and make sure that they are not clogged or full of debris. Clean any filters according to the instructions for your model or replace the bag. Excessive debris will make the engine run noisily.
Inspect the hose of the vacuum and remove any large debris that may be clogging the inside of the tube. Large amounts of dust, as well as stones or other hard materials that bounce, may cause a loud noise in the engine.
Remove the housing that conceals the engine of your machine and inspect the fan for damage or clogging. Remove any dirt or debris that may hinder the movement of the fan. Inspect the fan for any damage such as bent or excessively sharp blades. Replace the fan blades as needed; contact your vacuum manufacturer if the fan is damaged. The replacement part will include instructions.
Tighten the fan with a ratchet if it is loose on the assembly. A loose fan will make a rattling sound as the motor revs.
Wipe dirt and dust from the frame of the engine. Large quantities of dirt or dust around the motor can cause it to overheat, which can cause vibration and loud noise.
Look for corrosion around the engine. If the engine is corroded, it must be replaced.
Grease the bearings of the engine if you hear a grinding noise from the vacuum. Greasing is often performed through ports in the engine, or by removing the bearings. However, the actual greasing method is model-specific. Consult your owner's manual or send the vacuum to a service professional for this service.
Inspect the inside of the vacuum cleaner for other worn parts or broken pieces. Worn or broken pieces can cause loud noises to occur. Remove the broken part and order new materials from the vacuum manufacturer or take the machine in for service.
Hope this information was helpful to you. All the best. Elect_Comp
Sep 05, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to assemble the hawaiian breeze oscillating floor fan
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
What is the cause of the loud noise in my vaccum it's a eureka boss bagless
If it's a rattling type noise, its possibly something in the fan assembly, including a broken off piece of the fan.
It could also be something loose near the roller brush, including a piece of the belt.
Nov 18, 2010 | Eureka 5856BVZ Boss Bagless Upright...
I need a manuel to replace a broken fan on my g4 kriby
We have actually recorded a very informative do it your self video on how to replace the fan on a Kirby Generation upright.
The video is a two part video, but this explains step by step how to remove the old fan, and put the new one on.
If you need to purchase a new fan assembly, here's a link to the Fan assembly for your Kirby G4. Unfortunately you may only purchase them as a complete assembly:
Genuine Kirby Vacuum Fan. Kirby Part # 119096S
Here's the videos showing how to replace the fan:
Part 1:
Part 2:
Hopefully this helps you with your problem! If this did help, please be so kind and rate the repair, or leave feedback for me. This is very appreciated by the Fixya community when someone is able to answer your question, and assures that experts continue to answer free questions, instead of just the premium paid questions.
Thanks again!
Chris Jones
GoVacuum.com
May 15, 2010 | Kirby G4 Bagged Upright Vacuum
Motor suddenly louder
Broken plastic fan inside motor, or even one blade broken will cause it to run off balance thus creating a load noise that will progress into motor damage. Replace fan immediately.
Oct 27, 2009 | Vacuums
Replace Kirby legend II fan (impeller blade)
In order to replace the fan you will buy a 2 or three piece lexan fan kit containing the fan a spacer and shaft.
You must remove the carpet head and then looking from the back of the machine you will find a series of philips screws on the outer edge of the fan housing facing towards the front, several of which may be partly covered by the motor housing. You will remove the forward facing screws to allow the housing to separate and reveal the fan.
If you are lucky there will be a sideways hole through the impeller shaft allowing you to slip a nail through to help twist the saft to unscrew it while holding the fan .
The shaft will turn off revealing a threaded motor shaft with spacers which the broken fan will slide off revealing a second spacer at the back . Be sure to replace these spacers in the same order when re-assembling the unit. Secure the shaft hand tight. Post back to advise if you need further help
Oct 07, 2009 | Kirby G4 Bagged Upright Vacuum
Replacing the fan hub on a kirby classic omega 1CB
I resolved the problem .I found a way to hold the armature shaft still while I unscrewed the pulley drive nut ,which must be removed in order to remove the vacuum fan.
> There probably is a special tool somewhere that would fit over the armature ( the metal part that spins on the shaft of the motor inside the stature) to hold it still ,but since it was suspiciously omitted from the rest of the fan blade parts ,I had to fabricate one myself.
>I happen to have three ,steel blade ,broad paint scrappers which were about 2 to 3 inches wide and thin enough so there blades fitted nicely into the groves that run the length of the armature without damaging it, as would be the case with a narrower screw driver blade .
>Bracing the handles of the 3 scrapper blades in a slot that was in the side of the case ,which was probaby its' intented purpose, held the armature shaft still while I unscrewed the fan nut which happened to have a reverse thread.( turns clockwise to loosen) .
>It unscrewed with ease. Problem solved!
Aug 30, 2008 | Kirby Heritage II Vacuum
The fan blades under the motor are broken i like my dirt devil triangle please help fix it.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=758276
Posted by roadrunner19 on Jul 08, 2008
The fan blades under the motor are broken I like my dirt devil triangle please help fix it.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Changing the fan should not be a problem; it happens every so often if you pickup something big and the plastic fan breaks. The cost to repair is about $10.00 to $20.00 plus labor and you can repair it yourself if you are handy or take it to a local vacuum cleaner dealer in your area and they can perform the fan replacement. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 08, 2008 | Vacuums
Vacuums Logo
412 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
