Question about SmartDisk Crossfire Desktop (xf160f) 160 GB Hard Drive
SmartDisk Crossfire Desktop Drive
My SmartDisk Crossfire Desktop 160 GB external Harddrive is not always recognized by win xp on a usb
  • Ronald Meyers
    Ronald Meyers Apr 23, 2008
    Unit is connected to external power
    Scholar:
  • 125 Answers
Usually this is a problem with the usb port not being able to supply enough power to the drive. Often, units like this will come with two usb plugs on one cable to increase the current supplied to the drive. If the drive has an input for external power (some do, some don't), then using external power would help.
Posted on Apr 23, 2008
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Crossfire wont back up from Windows 7
1.
Connect the external hard disk drive to the computer. Make sure that the external hard disk drive is powered on.
2. Create a Windows 7 system repair disc. To do this, follow these steps:
Click Start Collapse this imageExpand this im, type create a system repair disc in the Start Search box, and then click Create a System Repair Disc in the Programs list.
Follow the instructions to create the disc.
3. Note You must have a CD or DVD burner to create a system repair disc.
4. Start an elevated command prompt. To do this, follow these steps:
Click Start Collapse this imageExpand th, type command prompt in the Start Search box, right-click command Prompt in the Programs list, and then click Run as administrator.
5. At the command prompt, type the following command, and then press ENTER:
C:\Windows\System32\REAgentC.exe /disable
6. Disconnect the external hard disk drive.
7. At the elevated command prompt, type the following command, and then press ENTER:
C:\Windows\System32\REAgentC.exe /enable
Note This operation might fail. In this case, if you have to have access to recovery tools, use the Windows 7 system repair disc that you created in step 2.
8. Reconnect the external hard disk drive to the computer.
9. Start the Backup and Restore Wizard to back up your files and data to the external hard disk drive.
Hope this helps
Sep 26, 2012 | SmartDisk Crossfire Desktop (xf160f) 160...
My crossfire hard drive is clicking and is not recognized by my computer as an external drive.
It's died, if its under warrently get it looked at quickly before the warrenty runs out.
Otherwise you need to use a data recovery company, if you need I can advise on some good ones that we (MCSLondon.co.uk) use
Oct 29, 2010 | SmartDisk Crossfire Desktop (xf250f) 250...
It isnt regestering my usb external harddrive onto my computer.
with some external hard drive you may have to install whats called a driver did it come with a cd? if not then you canask the person that you got it from.... make sure that your computer supports usb 2.0 good luck!
Dec 18, 2009 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Vista drivers for smartdisk 160 gb crossfire harddrive computer does not recognize drive or install the hardware
A few things to check but assumes USB for other interfaces similar steps may be followed
1. ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer.
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply (Dont use any other unless you know it has both the same voltage and current rating eg. 12V 500mA anything rated below that would not work properly)
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select computer management.
Now select Disk Management and expand the window.
Your drive should be listed here (if not then you need to check your computer hardware has not got any issues before proceeding)
If your drive is listed and says healthy then right click on it an select Properties, click tools and then error checking, Check now, tick the two boxes and then start.
This will attempt to fix any errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed ut did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. when it is done restart your computer and you should be good to go.
Aug 16, 2009 | SmartDisk Crossfire Desktop (xf160f) 160...
Smartdisk 160GB Crossfire hard drive
I had this same problem. One option is to open the smartdisk up. It should have a seagate ata drive inside. Attach it to a computer as a slave drive. Your dive will appear as a secondary drive on your computer. you should be able to get all your files off the drive. If your worried about voiding your computers warranty you can buy a usb adapter to make the drive act as an external drive. I highly recommend never using this drive again. I used it as my main hard drive and it fried on me. If you plan on getting rid of this drive let me. I need the circuit board to get my music files and portfolio off my failed drive. Thank you.
email: bizzybone@csufresno.edu
Mar 26, 2009 | SmartDisk Crossfire Desktop (xf160f) 160...
USB External hard drive 160 GB not recognized by desktop Windows XP OS
Very possible your problem is that this drive is not externally powered and your desktop does not put out enough power to drive it.  I'm guessing your desktop is older.  Especially if your desktop is USB 1.0 this problem would occur.  Your best bet in this case is to either mount a newer USB expansion card into your desktop, or get another externally powered harddrive and transfer data over to it from this one with your laptop.
Nov 01, 2008 | Verbatim SmartDisk Firelite Portable USB...
Drive F: No more, HELP!!!
try changing your usb port the info on drive should still be there also if this didnt help try reinstalling driver software sometimes corrupt files happen for drivers
May 16, 2008 | SmartDisk Crossfire Desktop (xf160f) 160...
Our crossfire doesn't work
Usually this is a problem with the usb port not being able to supply enough power to the drive. The current is often limited at the usb port, and the hard drive may need more than what is being supplied. This is a common problem, and the drive itself is usually fine. If the usb cord has 2 usb plugs on it, plug them both in. If you have an external power jack on the drive, use it.
Dec 17, 2007 | SmartDisk Crossfire Desktop (xf160f) 160...
SmartDisk Crossfire Desktop (xf160f) 160 GB Hard Drive Logo
231 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
