Photosmart 380 printer has only ben used with a cf. memory card until today when a sm/xd card was inserted, now I have a error message card access error. when I have tried to use my cf. card
When XD card is inserted printer says "card error"
Posted on May 08, 2008
What does the card error mean
Can be lots of things. Would have been handy, if you had told what card you are using. Your camera can work with CompactFlash, Microdrive and xD-Picture cards.
If you did not insert the card(s) you are using, correct, or you removed the card in a wrong way, you could have damaged the cardholder, causing an error you probably can't repair yourself. The CF and Microdrive you can remove by pressing the eject button. The xD-Picture card you can remove by pressing in the card, and release it. The card comes out.
Then you could have damaged the file system, by opening the card cover, while the card access lamp was blinking. What ever card was in, the filesystem can be damaged.
Then you can have two cards in, Both, o CF of Microdrive and a xD picture card. Some settings are required for the camera, to know hat card it should use.
If you have an Microdrive, the drive can be damaged, by a magnetic file, or the drive just stopped rotating. A micro drive is actual a miniature spinning hard drive.
First check if the memory card is inserted correct. Eventually, remove it and check all contacts, on the card and in the camera. Then try formatting the card. If you think there could be important pictures on the card, put it in a external card reader and use a recovery program, to see you can recover the pictures on your computer. Programs can be found on the net.
If you can't format the card, check if you have a Microdrive. If so, try to replace that with a CF or xD card.
I hope something is to any use for you.
Next time, please give us some more details. I know you exactly see and know what is not working, but we only can use your description. And only what you give us.
Feb 16, 2014 | Olympus E Cameras
PHOTOSMART 2575 DISPLAYS "MEMORY CARD
Insert a memory card (in my case a SD CARD) and SLOWLY extract card until error message clears and normal screen images appear.I had to do this several times but it worked for me but cannot guarantee it will for everybody.GOOD LUCK.
Jun 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
I put a CF photo card into the CF/MD slot right above the SM/XD card slot on my computer tower and the CF card kept going and is not inside the tower. How do I retrieve it?
It has to be in the card reader, it sound like it was inserted into the wrong slot and fell into the card reader. You may have to take apart the card reader to get your media back.
Oct 21, 2010 | ASUS Computers & Internet
Hp photosmart 3210 all in one memory card error no memory card is inserted but this error message persists
Try the same memory card in a pc to check if it works ... if it does then check the slot where the card gets plugged in... try a different card that also does not work means printer memory card slot is bad
Apr 29, 2010 | HP Photosmart 3210 Printer
Have a aspire 5735 laptop need to know how to insert sd compact flash disk
If your laptop does not have a built-in memory card reader then purchase an USB multi memory card reader that can read a variety of memory cards such as SM/XD, SD/MMC and CF/Micro drives memory cards.
All you need to do is plug in the memory card into the card reader and then plug the card reader into the computer's USB port. The computer will see the memory card as an external memory device.
Aug 03, 2009 | Aspire Computers & Internet
Hp photosmart 2610 won't read my sandisk ultra memory card
Previous solution is the FAIL. Original poster says it works fine in _camera_, but not in _printer_. _Printer_ is the compatibility issue, not camera.
Feb 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
Wont accept xd picture card
Hi, tecnil
Device cannot detect files on the memory card.
Cause
The memory card might be missing or inserted incorrectly. Verify that the memory card is inserted correctly.
The files might not be in the correct format. To print from the device control panel, the files must be in the sRGB JPEG format. To print other formats, you must use a software program on your computer.
You might have inserted more than one memory card. Only one card slot can be occupied for the device to detect JPEG files. Verify that only one card is inserted.
oke,
thx
cropp
Jan 08, 2008 | HP Photosmart 7450 InkJet Printer
"card error"
Have you tried formatting these cards in your camera? You will find the setting in the menu as per page 26 of the manual. Also check that the correct card type is set for xD or CF as appropriate. You can download the manual from the link below: http://www.olympusamerica.com/files/EVOLT%20E-500%20Advanced%20Manual.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 02, 2007 | Olympus EVOLT E-500 Digital Camera
174 people viewed this question
jasbo
jasbo
