Question about Sony Cyber-shot DSC-N1 Digital Camera
When I try to charge the battery the light just flashes and the charger does not work.
  • Anonymous May 11, 2008
    I try to charge, and the red light just blinks and doesnt charge
  • 3 Answers
Hi, I had the same problem!
Had not used my camera for a while so I decided to but my battery on charge, once in the charger the orange light just kept flashing so I left this in "flashing" for a good hour or so.
I removed it and then replaced it, and it was still flashing so I decided to get a new battery (£40!).
I put the new battery on charge over night and it charged great, so I thought I would re-try charging my old one before I sent it away for recycle, and guess what the orange light stopped ON and it was charging!
Not sure what happened here, it was either charge the old for an hour with light flashing and then remove and leave over night and re-try OR insert a good battery to re-set the charger?
But I now have 2 good batteries.
Hope this helps :)
Posted on Jun 17, 2008
SOURCE: Battery will not charge
Yep. Same hear. Casio will replace with reciept - call 1300 728 606. Pitty I've lost mine!
Posted on Jan 02, 2008
SOURCE: problem charging battery
it your batter light is blinking a red light then you should call up casio's technical service and they'll send you a new one:)
call 1-800-435-7732 for technical support! :)
Posted on Dec 31, 2008
SOURCE: My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Posted on Jul 21, 2010
Rammsteins
  • 300 Answers
SOURCE: when trying to charge my battery... the light
Battery problem. Well known problem with the NP-20 battery. It can be repaired by connecting it to ~4-4.5V 1-1.5A for about 5-10 seconds and then charged normally with the charger.
Of course a new battery will be better.
Tom
Posted on Aug 02, 2009
SOURCE: Battery charger light flash
Use the 9V as Ricckk suggested in Solution#2 and it works like a charm (make sure you hold the 9V against the casio battery for about 20secs with the the right polarize i.e. + with + and - with - ). As well as the phone number Dobetta gave in Solution #4. I now have a spare. Thanks Ricckk and Dobetta.
Posted on Jun 18, 2008
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
DW911 charge light flashes when no there is no battery in radio
Sometimes when a battery is too low it takes a while for it to initialize in a charger and begin to charge. Clean the battery contacts with a pencil eraser and put it back on the charger. Leave it on the charger despite the blinking light. Leave it on the charger for several hours and see if the flash stops and it becomes a constant light indicating normal charging. If this does not work, you may have a short in the battery or in the charger itself. Try another known good battery in the charger and see if you have the same problem. If so the charger has an issue.
Best regards.
May 22, 2013 | Radio Communications
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
My dc18ra makita battery charger flashes red and green lights no matter how many bateries i try
The pcb inside the battery has a microcontroller that monitor the charges and charge cycle. When the cell falls below a certain voltage, it will instruct the charger not to charge and will show with a red-green flashing light. If the battery has been tried 3 times in succession then the pcb will brick itself from the makita charger. So first replace the bad cells. There are 2 solutions at this moment: charge with a 3rd party lithium charger like the imax b6 or replace the pcb with a working one. check out my blog on http://mkbl1830.blogspot.com/
Mar 17, 2012 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Yellow and green light are on but wont charge battery?
If both lights are on and both are flashing the charger is reading the battery as defective and the charger won't charge the battery. If the Red light (yellow if plastic is faded) is on and the green is flashing the charger is trying to charge the battery. If the battery won't charge replace it.
Dec 21, 2010 | Ryobi Multi-Volt Battery Charger
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
CHARGER PROBLEMS
The flashing light indicates the charger is charging the battery (or attempting it) and if it never finishes charging you should try to charge a different battery, if the charger charges that one ok then the battery is bad.
Jun 18, 2010 | Dewalt 18 Volt Compact Drill Kit
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Battery charger flashing red light
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Nov 03, 2008 | Olympus Stylus 710 Digital Camera
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
Sony Cyber-shot DSC-N1 Digital Camera Logo
1,874 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
