Question about Sharp AL-1642CS Copier
Scanner take a minute a page using form feed.
Since I have purchased the sharp machine when I go to use the form feed scanner of the machine it will make a bunch of noise and gurgling sounds before it finally runs the light bar over to the form part of the machine and then scans only 1 page, then returns home only to go through the whole process all over again making it take almost a minute per page to scan.
I use the scanning part of Windows but I have also installed the complete suite that came with the unit and the same thing happens . How do I get it to scan all pages before returning the light bar to home . I'm using X. P. pro as my operating system
Help
Joey D
  • Sharp Expert
  • 1,326 Answers
Yes, there is something you can do..... Get a bigger and faster copier.. There is not much you can do.... It is slow..... Sorry, can not help you with that.
Posted on Jun 05, 2008
L1-00 Sharp Al 1655cs
scanner feed trouble, turn machine on and off , if problem persists then check enchoder strip under scanner glass and scanner connection
Jun 30, 2014 | Sharp AL-1655CS Laser Printer
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
Its a Sharp AL-1631. It'll copy from the auto feed
Check under the scanner, there is a scanner lock that you may have hit removing copies. Its most likely in the locked position and stopping scan.
Jun 03, 2011 | Sharp AL 1631 Copier
I have Sharp AR 5316 L1 00 error in my copier pls give tips urgent
L1 00 Content Scanner feed trouble.
Detail The scanner does not complete feeding in the
specified time.
Cause Mirror unit abnormality.
The scanner wire is disconnected.
The origin detection sensor abnormality.
Mirror motor harness abnormality.
Check
and
remedy
Use SIM 1-1 to check the mirror reciprocating
operations.
When the mirror does not feed.
Check for disconnection of the scanner wire.
Check the harness and the connector between
the mirror motor and the MCU PWB.
Replace the mirror unit.
Replace the MCU PWB.
When the mirror does feed.
Use SIM 1-2 to check the mirror home position
Jul 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
We own a Sharp AR-M277 copier, scanner, fax machine that we use on our network. The scanner feature worked great, however, after 500 scans it stopped working. Someone told us that it was just a trial &...
The machine was put in a demo mode for scanning. What you will need to do, is contact an authorized Sharp dealer and purchase an MX-NSX2 kit and that will enable scanning and also purchase you a copy of a program called Sharpdesk.
May 13, 2009 | Sharp AR-M277 All-In-One Printer
I am trying to get the scanner working on a Sharp AR 336
The Sharp website does not seem to have this model listed.
Try this LINK and fill in the enquiry form.
Good Luck
Jul 02, 2008 | Sharp Office Equipment & Supplies
Missing pages
Your Doc feed needs new Rollers and Seperation Sheet/Pad, it is pulling pages, but not all the way, while the scanner continues to scan. the ADF might also need adjustment.
Jun 11, 2008 | Sharp AR-M237 Copier
Doc not feeding
You need a new paper feed tire assembly
Nov 24, 2007 | Ricoh Aficio IS420 Flatbed Scanner
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
