How do i attach a Wall Mount to the TV?
I need to attach a wall mount and i cant find where it goes on the TV, Can someone Help me figure it out? How to attach Flat Panel Wall Support to back of AKAI LCT2721AD LCD Flat Panel TV
  • Anonymous Nov 29, 2008
    how to attach wall mount to LCD TV?
    Problem Solver:
  • 11 Answers
I have the same TV, and I bought a mount with 4 connector holes. I was able to connect 3 of the 4 and it has been fine as the TV does not weigh too much. The TV was not designed with the current mode of either wall or stand mount. It was just intended for stand. I have had it on the wall for over 2 years.
Posted on Jan 02, 2010
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
What size screwsare used to attach wall mount
Wall mount for what size TV?
The answer is probably in the instructions that came with the wall mount.
I need: Size of TV.
What kind of wall you want to attach this TV to.
Remember, I am far away and can't see what you are doing.
Aug 19, 2014 | Televison & Video
Wall mount Sanyo LCD-32xr8DA
look at the middle of the tv the 4 screw mount thats wre the tv wall mount gos. good luck
Jun 15, 2013 | Televison & Video
How does the tv mount?
1- remove the wall plate from the arm.
2- fix the front plate to the back of your television.
3- mark the position of the holes and drill
4- put wall plugs into holes.
5- secure the wall plate to the wall
6-attach the arm to the wall plate.
7-hang the screen on the arm (i recommend having someone help) and secure it in place
Mar 05, 2011 | OmniMount "OmniMount 23" to 42" 4in1 Flat...
Want to wall mount tv but don't don't were to bolt.
I have my 32" Protron mounted on my wall. There are six holes on the back of the set that you attach the mount. I cant find any links to pictures but it should be pretty straight forward. You should be able to use any generic LCD wall mount, just make sure it can hold an 32" since I made the mistake thinking all wall mounts were the same. I purchased mine at Best Buy but you should be able to find a mount anywhere. You will need to fasten the mount onto the studs in your wall. Drywall by itself will not be sufficient and cannot support the weight of the TV.
The wall mount should come with everything you need, e.g., screws, brackets, etc., with the exception of the tools. FYI... it's not going to be an easy job so be patient and take your time. It's probably going to take the good portion of a day. Also, as for the holes on the back, just be careful when performing the final mount to make sure it doesn't fall. It would be wise to have someone help you.
Nov 25, 2008 | Protron PLTV-32 Television
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Attaching to wall mount
The 4 screws that are commnly used are short because they are ususally wide in diameter. Besides if they are too long then they might damage the boards on the TV.
Apr 13, 2007 | Akai LCT2716 27 in. LCD Television
Televison & Video Logo
564 people viewed this question
Top Televison & Video Experts
