Question about GALAXY Microsystems 55622
Water filter Were do I find the water filter in my refigerator?
  • jjnoahjen Jul 17, 2008
    I can not twist my filter off to replace it?????
Open the freezer door and look in the grill between the bottom of the freezer and the floor. Some might have a push button and twist type, but mine was twist only. It would only twist 1/4 of a turn (until knob is in vertical position), then pull out.
Posted on Jun 08, 2008
My freezer
If you have an Ice Maker and/or Water Dispenser with this unit the red light is telling you the water filter is now time to change.
The filter is usually under the front refigerator (behing the bottom cover plate). The filter is about 8" long and 2" wide. Looks kinda like a big white hot dog bun. Remove the filter cover and spin the filter cartridge counter-clockwise and pull it out. A little water will leak but it'll close itself off as soon as it pulls out.
Reinstall the new filter the reverse sequence and run the ice water for 3 minutes or 3 to 5 gallons of water to get all the fatory carbon filter sediment flushed. The light will now turn to green.
Should be all better now.
Nov 23, 2012 | Refrigerators
Hi I have a Whirlpool Refigerator and it drips water from the frezzer into the refigerator thru the two opening up in the back middle opening from the frezzer to the refigerator. It does this off and on
sounds like the drain live from freezer to outside is clogged. the water isnt making it you the condensate pan but coming out in the refrigerator. try finding and cleaning the drain line.
Mar 02, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a GE Profile refigerator ( model # PSCS3VGXAFSS ). I have had it for a year. It is still under warrenty. The question that I have is that the ice maker just stoped making ice. It goes through all of...
There is a dual solenoid water valve. One solenoid controls the water dispensor the other is for the ice maker. If its under warranty you should definitely have it looked at.
Sep 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
I HAVE A 1992 KENMORE REFIGERATOR TYPE 22 SS A 92 WITH THE ICE MAKER AND WATER. DID THIS PATICULAR MODEL HAVE A WATER FILTER BUILT IN. IF SO WHERE WOULD IT BE LOCATED?
Generally a filter is a add on feature. If you do not see a filter in the water line that supplies the ice maker then there is generally not a filter. You can purchase a water filter from any local hardware store and install it yourself.
Aug 04, 2010 | Refrigerators
I need a part number
google this part number 5231JA2006B
Dec 01, 2009 | LG LFD21860ST Stainless Steel Bottom...
How do you replace the water filter?
If you have a built in water filter it should be located in the refigerator compartment in the back right hand corner. It just unscrews and drops out. Hope this helps
Jul 29, 2009 | General Electric GSS22JET Side by Side...
Three year old Whirlpool Refigerator (ED5FHEXNB), water leaks from bottom of refigerator when outdoor garden hose water is turned on. Only leaks when outdoor garden hose is turned on. Water filter, Brita...
Hello it sounds like you have a leaking water hose which you need to find. maybe check first where it connects into the back of the unit.. Otherwise the fridge has a blocked drain in the freezer. cheers
May 15, 2009 | Refrigerators
Water filter on refrigerator not working. Samsung
This link will take you to the Samsung support site. There you can find the instructions for replacing the filter....if the filter is not properly aligned, the water bypasses the filter
Jan 30, 2009 | Samsung RS2630WW Side by Side Refrigerator
GALAXY Microsystems 55622 Logo
226 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
