Jeep Grand Cherokee 2001 3.1 turbo diesel. Low coolant level light comes on on dashboard after 10 seconds. I have replaced the sensor and checked coolant level but light still comes on. Vehicle has only done 56000miles but I had light come on about 12 months ago and problem was cylinder head gasket. Had that done and all was well until light came on again about month ago. I've had cylinder head tested and ok. Any clues as to the solution would be appreciated
  • 1 more comment
  • v31cox Apr 25, 2008
    I do not have a lot of faith in your ability to solve my problem if you think its to do with air conditioner. I await your reply.
  • Anonymous May 14, 2009
    Grand Cherokee 2001 3.1td. Problem the low coolant light came on when i started it the morning, i checked the coolant level and saw that it needed about a cup of coolant. after i added the coolant the light stikl stays on. have no idea where to start looking. it is the firts jeep i drive.
  • mielie5 May 15, 2009
    looks like this is a common problem there must be somebody out there with info to share on this topic, my jeep also have the same problem low coolant light just came on one morning, and when i checked it needed about 200ml of coolant since then it does'nt want to go off, since i filled it up it stays full, oil looks fine drive's ok no other problems.
chillmaster
  • 104 Answers
SOURCE: My goodman heat pump has
After system has been running 10-15 minutes, the discharge air temp should be 18-22 degrees colder than the air being sucked in. If the air is more than 22 degrees colder then the problem is with air flow. Check filters, blower speed, make sure all vents are open, is indoor coil clean. If the discharge temperature is less than 18 colder, then the problem is with the refrigerant portion of the system (low charge, improper flow control of freon into coil) the key is if you have an orfice or a TXV (Thermal Expansion Valve) to control the flow of refrigerant into the coil. TXV's are known to fail with intermittant problems, however, most 10 seer systems do not use a TXV, they use and orfice which could have debris in it affecting the flow of freon. Hope this helps. When you rate my solution, please keep in mind that I am a technician that normally diagnoses equipment by checking it out in person. I do the best that I can with the information that you provide me on Fix-Ya.
Thank You,
Chillmaster
Posted on Jul 07, 2008
  • 311 Answers
SOURCE: flame roll out protection device
No, heat exchanger is most likely cracked. Time for a new furnace. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 29, 2008
  • 30 Answers
SOURCE: 2005 Nissan Sentra 1.8s...SES light on. PLEASE HELP!
well if the head gasket has been replaced you shouldnt smeel any coolant. But have you check your coolant hoses???? for leaks or any coolant on the driveway, when your car has been sitting there overnight!???
Posted on Dec 15, 2008
SOURCE: coolant level sensor bad warning comes on console
I have the same problem with my 97 Jeep. I found a fix on www.jeepforum.com posted by phild328, goodluck
Posted on May 07, 2009
polarcycle
  • 1392 Answers
Coolant sensor wiring would be the next place to look. Make sure connector is good, and look for broken wires.
Posted on May 31, 2009
So, my 2001 V8 Jeep Grand Cherokee Laredo is very slowly leaking coolant. I replaced the heater core in 2009 and the symptoms that the Jeep expressed then are not happening now. However, the low coolant...
are you mixing the coolant with water if yes,you need to just put straight up anti freeze ,because water evaporates at high temperatures .. also keep resorvoir full at all times there is a sensor in the tank that when is low it makes the check coolant light come on ,,....good luck
Mar 21, 2011 | 2001 Jeep Grand Cherokee
The coolant sensor light is on
The coolant sensor liight come on when the Anti-freeze get low. Just top off the ant-freeze and the light will go out. It is norrmal for anti-freeze level to go down but slow. Toping off once or twice a year is ok but anymore then that you really should check for leaks. Low anti-freeze will cause over heating. Over heating can wreak an engine.
Oct 23, 2010 | 1996 Jeep Grand Cherokee
My dad put a new thermostat in my 2001 Jeep Grand Cherokee and it is now telling me my coolant is low and it is not. I just need to know how to reset this.
your low level sensor may be stuck sometimes a light tap on the sensor will repair the issue,make sure your coolant level is ok in the radiator and the overflow tank
Jan 19, 2010 | 2001 Jeep Grand Cherokee
Coolant level sensor bad warning comes on console
May 31, 2009 | 1997 Jeep Grand Cherokee
Apr 04, 2009 | 1997 Jeep Grand Cherokee
1999 Jeep Grand Cherokee Lerado, low coolant alarm
This same thing happened to mine. It only happened in really cold weather though. I added a few inches more of coolant into the overflow. It fixed the problem. I also discovered if that is not the problem, the sensor in the overflow can go out and a replacement is about 20 bucks.
Jan 11, 2009 | 1999 Jeep Grand Cherokee
Heating & Cooling Logo
188 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
