Soltek SL-65KV2-T Motherboard
Problem for Soltek SL-65KV2-T Motherboard
PROBLEM WITH MONITOR NOT SWITCHING ON ON SOLTEK SL-65KVB/KV2 MOTHERBOARD
By wetcornflake on Apr 23, 2008
A WHILE AGO I THINK I HAD A VIRUS OR SOMETHING, BUT THE COMPUTER BLEW A FUSE WHILST IN USE, WHEN I REPAIRED THE FUSE AND RESET CMOS AND THEN SWITCHED THE COMPUTER BACK ON, THE MONITOR DID NOT WORK, IT SEEMS IT DOES NOT GET A SIGNAL FROM THE COMPUTER TO TURN ITSELF ON. AFTER I HAVE TURNED THE COMPUTER ON/OFF 2 TO 3 TIMES THE MONITOR CLICKS AND STARTS WORKING. I HAVE AN IDENTICLE COMPUTER AND THE MONITOR WORKS FINE SO ITS GOT TO BE THE PC
I HAVE RAN THE SOLTEK CMOS INSTALL DISC BUT IT MADE NO DIFFERENCE
HELP
Best Solution
posted on Apr 24, 2008
Helpful)
onlinepc-fix
Rank: Master
Rating: 86%, 16 votes
Hi, does the pc load up to bios and does the pc power up, how did you reset cmos was it by the jumper or by the battery if you done one try the other. If none of that works, you may off blew or damages the power supply unit, you could of also damaged the motherboard which can happen because this same thing happened to me. and the cpu may have been damaged. get back to me with more details of what i said above and are see what i can do for you. Thanks
Onlinepc-fix
lee
Was this helpful?
Yes
No
Popular Solutions for Soltek SL-65KV2-T Motherboard
Questions and Unsolved Problems for Soltek SL-65KV2-T Motherboard
Do you recommend Soltek SL-65KV2-T Motherboard?
Answer
Answer
Poler Expree O gauge Train, working all morning..Train goes arou7nd but the throttle is not... (More)
Answer
no video driver present since a reformat and can't seem to download, motherboard is a k8m400 for an... (More)
Answer
I need the manual for motherboard P6V693A/A5-133 by QDI
Answer
driver contoller video
Answer
how do i find the motherboard # on a IBM Aptiva e 2270 computer?
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
