Question about Refrigerators
In replacing a GE SmartWater filter on my GE profile side by side refridge the water will not flow thru new filter, why??
    Genius:
  • 1,447 Answers
Here the link for the manual
Posted on Apr 23, 2008
    Genius:
  • 3,587 Answers
First thing is to make sure it's installed in proper direction. Those have arrows or other marks to indicate inflow/outflow. Please check that first.
Ge smartwater plus
The problem would not be from your water filter. The water is controlled by the dual water valve inteh back of the fridge. The water valve will most likely need to be replaced. It's possible that a small piece of debris found it's way to the ice maker water valve after disturbing the filter. It's also possible that the ice maker is at fault too, causing the valve to stay energized too long. Although if the valve stays energized too long it will eventually burn out. You can try unplugging the 2 wire plug to the ice maker valve to see if the problem stops first, if not than you will need to replace the water valve unit. Pleazer Appliance...
Sep 02, 2014 | GE Profile PSW26P Stainless Steel Side by...
Im at the six month point, red light flashing, which of the filters do i replace and do i need to sanitize the storage tank?
The filters that you should replace every the six months are the two pre/post filters (FQROPF). The membrane (FQROMF) needs to be replaced every 1 to 2 years. During the filter change, bacteria could be introduced, so it is recommended that you sanitize the tank while changing the filters. Here are the filters you need to replace:
http://www.freshwatersystems.com/p-7787-ge-profile-fqropf-smartwater-ro-pre-and-post-filter-set.aspx
Apr 09, 2013 | General Electric Profile Smartwater Ultra...
I just installed 2 new GE-GXWH40L filters installed on each side of my new GE water softner. I can not get water to go through the filter. Works fine in bypass. I triple checked the flow direction and it...
This is proabably not the case but I have seen it happen, Have you checked the outlet side of the filter to make sure it was drilled when it was made. Thank you
Nov 29, 2010 | General Electric GE SmartWater Household...
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
Replaced the water filter. the refrigerator is making ice but not dispensing water
Is there any packaging from the new water filter restricting the flow. Check for anything blocking the water flow near where you replace the filter and check for correct installation. If this problem was the reason you replace the filter check the switch that dispenses the water. Make sure it isn't "iced up".
Sep 30, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE smartwater filter (model GXRLQR) stopped working...help!
These replacement filters (GXRLQR) are FLAWED straight out of the factory. The problem is in the 2 little "teeth" nubs that stick up near the center circle of the filter. When the filter is twisted and inserted, these teeth push up on a tiny black spring loaded valve in the body of the filter, alowing water to pass through up and out the spigot. The flaw is that the "nubs" are too short and do not push open the spring valve far enough, reducing flow to a semi-trickle, even with a brand new filter. GE seems to think this is not a problem.
Solution=stick a $0.25 garden hose rubber washer in the top of the filter and screw it in. You may have to try a few times to get it to work and seat properly. When it works, you'll immediately get a nice super flow of water. Better than upgrading to a $200 filter system recommended by GE...
May 06, 2010 | General Electric GE SmartWater Household...
I just installed a new MSWF water filter cartridge on my GE Profile refrigerator. After pushing the reset button, there is no water flow at all. I can hear the pump humming. I tried removing and...
Tried new filter. Thought water line frozen. Problem solved by bypassing the water filter. Now that I'm working without filter I will troubleshoot the filter receptacle.
May 04, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Slow water flow from GE SmartWater under sink water filter.
I solved the problem! The system's manifold (the plastic base you put the filter in) has small black conical shape button. When you tight the filter in, one of the two small triangle-shaped cams (located close to the filter's central hole) pushes the manifold's button, and this opens the water flow. The problem is that the cams are too low and do not push the button all the way in. Take a pliers and squeeze (not too much!) the cams, so they will raise a little: it will be enough to push the button to open the flow completely.
Mar 11, 2009 | General Electric GE SmartWater Household...
Replaced GE SmartWater filter in my GE refrig and water wil l not flow thru it,why?
We replaced the water line to the refriderature. It was plugged by a coroded copper sleve.
Apr 23, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
213 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
