Question about Whirlpool ED5GHGXMQ Side by Side Refrigerator
Cleaning Ice Dispenser
Can you remove ice dispenser to clean
  • 1 more comment
  • Anonymous May 27, 2008
    would like to be able to remove the clear plastic chute to clean.Past 9 years have sprayed with bleach solution, and slid thin palette knife wrapped in cheesecloth behind support,but not totally satisfactory.We have a Kenmore top mount model no. 253 or 970.
  • Anonymous Jun 02, 2008
    We cannot get the plastic shoot to move. I was told to lift up and pull out. Did not work.
  • bnoliver1981 Jun 29, 2008
    I have the same problem. Can't remove the plastic shoot and have tried bleach with q-tips, thin knife etc. Nothing works. Help!
    Genius:
  • 1,073 Answers
What is the model number
Posted on Apr 23, 2008
woodchuck789
  • 4070 Answers
SOURCE: Mold/Bacteria formed behind ice dispenser spout
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Although you may can clean it by just spraying everything you can reach with a spray bottle of bleach and water mix and let it set for a while and then rinse with clean water. Test an inconspicuous spot the check for damage. Or another mold killer may work just as well.
Posted on Sep 30, 2009
louislevel_2
  • 374 Answers
SOURCE: Ice dispenser will not stop. Motor continues to run even after re
hi there,
replace the lever switch it was already defective it always contactor normaly close,let the qualified techinician do this for you.
besure to unplug the unit before doing this.have a nice day.don't forgety to rate me,thank's a lot
Posted on May 05, 2009
tborn6
  • 700 Answers
SOURCE: Face plate around ice maker/water dispenser needs to be removed.
there are screws on the bottom of the plate. re,oive the drain pan underneith the dispenser and the screws are underneith that.
Posted on Apr 04, 2009
TheMobilian
  • 8220 Answers
SOURCE: ice dispenser door sticking. has been cleaned but still sticks
See page 38
Posted on Mar 25, 2010
  • 744 Answers
SOURCE: Remove and clean Ice and water dispenser for Model
Visit this link to see a diagram of the parts for your unit. You can see how things are arranged before you attempt any disassembly:
http://www.apwagner.com/index.php?main_page=model_lookup&model_num=ED5GTGXNQ00&model_id=147487&manufacturer=
Posted on Apr 26, 2010
How do you remove the in the door dispenser cup and lever for cleaning
Depends on the make/model, but usually there are a few screws that go in from the front that hold the plastic arms in place along with the spring blade. Most of the time you need to remove the decorative plastic cover around the front of the dispenser to get at them. Pay attention to how things go together, or take pics before and during the process. It will save you a lot of headaches later.
Mar 20, 2015 | Refrigerators
Firgidare ice dispenser dispensing ice without the switch bring touched. Is this a control board issue or something else?
try taking you ice tray and dispenser out and cleaning them of any frozen ice. sometimes the dispenser system kinda jambs and then stuck ice come out as it melts slightly and frees itself from the dispenser shoot and mechanism good luck
Mar 19, 2015 | Refrigerators
Frost inside the ice dispenser chute and the ice cube dispenser seems "stuck" on crush mode instead of dispensing full cubes.
The stuck on crush mode , is caused by ice frosted in front of the ice bin , blocking the ice bin flap from opening , when calling for cube ice . Removing the ice bin and cleaning or defrosting completely , will solve this problem , AFTER , resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Oct 10, 2009 | GE Refrigerators
Mold/Bacteria formed between ice dispenser and dispenser lever Can dispenser be removed from lever for cleaning? If not, how to clean?
Use a bathroom mold and bacteria remover spray available from most supermarkets. Also spray down into the feeder on the inside of the door. Make sure you rinse the area thoroughly after use and run water through the water chiller dispenser and run some ice throughthe ice dispenser and throw these away. Then it should be safe to use.
Sep 30, 2009 | Kenmore Refrigerators
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Apr 04, 2009 | KitchenAid Refrigerators
NO ICE
Check this first,
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
ice and water dispensers. To turn off the ice maker, see “Ice
Maker & Storage Bin.”
 Press and hold LOCKOUT for 3 seconds to lock the
dispenser.
 Press and hold LOCKOUT a second time to unlock the dispenser.
Let me know if this helped, Sea Breeze
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool(Model: GS6NBEXRL01) Side-by-Side has a sensor on the right side of the freezer and a flap on the left. The light is red and the icemaker is making ice, but will not dispense through the...
The Dispenser Lock (on some models)
ice and water dispensers. To turn off the ice maker, see "Ice
Maker & Storage Bin."
• Press and hold LOCKOUT for 3 seconds to lock the
dispenser.
• Press and hold LOCKOUT a second time to unlock the
dispenser.
Let me know if this is your problem, Can get the manual for you if you like, Sea Breeze
Feb 04, 2009 | Refrigerators
Ice Dispenser does not work.
Remove the ice tray and clean it throughly with warm water. Let it dry at room temperature and see what happens.
Jul 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Whirlpool ED5GHGXMQ Side by Side Refrigerator Logo
537 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
