Question about Lanier 1205 Copier
Misfeed on lanier 7320
Hi.. I'm afraid my 'ole copier is discontinued... it was still working fine, until, for no reason (wasn't feeding it or anything), it shows misfeed in the lid/feed section. There's nothing there to misfeed! Any thoughts?
kathy at cte
  • 87 Answers
Sounds like a dirty sensor or a small piece of paper stuck. Check the feeder, left side, underneath. There should be a switch actuator
in the paper path that is visible. Also, on the right side, check all of the openings for anything stuck. If you have no luck, get some canned air and blow out everything. If its still jammed, it can be easily unplugged in the back of the machine, and the machine section will still operate.
Posted on Apr 23, 2008
Problem on RADF misfeed but no misfeed at all. what should I do
please clean the sensors located in the RADF and power the machine and the problem is over
Mar 13, 2014 | Lanier 5222/27 Laser Printer
Very light copy in 2nd side copy
its a moisture issue in the paper. try nice new dry paper and i bet it works fine
Mar 17, 2012 | Lanier Office Equipment & Supplies
Lanier 5618. Misfeed "B"
check registration sensor actuator
Mar 26, 2011 | Office Equipment & Supplies
I have a black line on my copies. i have a lanier 7320 copier. Is it my drum?
It could likely be the drum. Is the line on copies and prints, or just copies? If it's just on copies, it's not the drum.
Jan 18, 2011 | Lanier 1205 Copier
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Sep 23, 2009 | Lanier Office Equipment & Supplies
Paper misfeed
Hello sir; Pull out the paper tray ,check the paper senser is moving freely,clean the paper pick up roller, it will take care the problem.
Aug 21, 2009 | Lanier Office Equipment & Supplies
Lanier 7320 error message c-41 can someone tell me whats wrong
I believe c-41 is a fuser problem. A trained copier tech may be required to troubleshoot.
Mar 19, 2009 | Lanier 1205 Copier
I like your pictures.... Have you tried to clean the feed roller with a slittly damp rag with Simple Green or WD-40? You can try that and wipe the extra off. They both clean the rubber roller's. If that works good, that means the feed rollers are worn and need replacing. But you may also need the paper pick-up feed clutch. You said you can still run paper throw the by-pass. Good Luck
Dec 11, 2008 | Office Equipment & Supplies
Paper Misfeed Problem
When you close the doors does the message disappear? If so then the paper pickup roller is worn. Open the cassette remove all paper apart from one sheet. Spray a alcohol based cleaned on the leading edge of the paper. Try and do a copy this will issue a jam and also clean the pickup roller. repeat a few times then clean out the cassette and dry off place new paper in the cassette and try. Also there maybe a piece of paper behind the cassette. Remove cassette and reach in and remove paper lodged at back.
Thanks Jason
Aug 16, 2008 | Office Equipment & Supplies
Lanier 7320 - Makes only all black copies
Was the toner bottle removed before you moved the machine?
Jun 09, 2008 | Office Equipment & Supplies
206 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Adorjani Laszlo
Anthony Karuku
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
