Question about Cameras
I just recently purchased a mdc 500se 5 megapixel camera. The problem that I am having is that the charger is not charging the battery anymore. I wanted to know if I could repurchase accessories for my camera?
  • 22 Answers
There are a number of causative problems that can lead to you battery not taking a charge, The charger itself may NOT be the problem, With a simple voltmeter it is easy to see if the charger is outputting the correct voltage. A multi-meter with a milliamp function can tell you if the current flow is correct by placing the meter in series with the the charging circuit (you can cut the positive lead from the charger to the camera and re splice it after the test is completed).
The voltage, amperage (charging rate) and type of current (AC or DC) is usually listed on the charger on a label or embossed in the plastic housing. If the voltage is OK but there is little or no current flow, the problem is probably in the battery- it has come to the end of its charge/discharge cycle and needs replacement. If there is no voltage coming from the charger it may need replacement but you must make sure it is exactly rated to accommodate you camera and battery, Batteries are DC. The input to you charger or the primary voltage is AC and needs to be stepped down and rectified to DC before it can safely charge the battery. Some chargers have the reactivation (conversion) built in to the charger- some have the output or secondary voltage still as AC and the rectifiers are in the camera. Just be sure all the specs match. If you can find the exact replacement unit- you don't have to take theses issues into consideration.. Sometimes the problem can just be a poor connection between the camera and the charger- check it out.
I hope this helps. Lightingman (Ed)
Posted on Apr 23, 2008
  • 477 Answers
Yes you should beable to get one off ebay. or goto radio shack and get a universal one.
I don't know how to charge my fujifilm ax600 series
The AX600 is a camera, not a battery charger. It uses standard AA batteries, disposable or rechargeable. If you use rechargeable batteries, you need to charge them outside the camera using a separate battery charger.
Oct 01, 2014 | FUJIFILM FinePix AX600 14 Megapixel...
How do i charge my kodak 8.0 digital camera
What model Kodak 8.0 megapixel camera? The M1063 is a 10 megapixel model.
Some Kodak cameras can charge the battery when you connect the camera to a power source. Some Kodak cameras come with a separate battery charger. Some Kodak cameras use disposable batteries. Without knowing the model of your camera I can't tell you how to charge your camera.
Jul 15, 2014 | Kodak EASYSHARE M1063 Digital Camera
Battery exhausted
Cheack to see if your charger is charging or take it to best buy and use their battery to see if thats it.
Jun 27, 2012 | Nikon Coolpix P500 Black 12.1 Megapixel...
My Polaroid t737 battery charger won't charge.
Having the exact same problem. Ordering a new battery but I suspect its the charger. If I figure this out I will post my answer.
Aug 02, 2010 | Polaroid T737 Digital Camera
BATTERY DOES NOT CHARGE Received a "Vivitar T328" camera yesterday. Inserted the supplied battery and a new memory card into the camera and connected the camera via "USB" cable to the supplied charger....
How old is the battery? If the battery is refurbished or old it might just not charge anymore.
Also, do you have a separate charger for the battery? Many cameras do and that is how they charge, not when the battery is still in the camera.
Apr 09, 2010 | Vivitar ViviCam T328 Digital Camera
Can kodak CX7430 be charged with USB
A USB connection will not provide sufficient power to your camera and it could damage the internal board. You could opt for purchasing a AAA battery charger or buy a charger/ac adapter from eBay as they go around 10$. The model you're looking for is kws0325.
Good luck.
Sep 06, 2009 | Kodak EasyShare CX7430 Digital Camera
When the battery is in the charger it flashes red & won't charge, have no idea what problem is! Have casio exilim lithium ion NP-20 battery & a casio exilim 7.2 megapixels camera. Can't turn camera...
I called casio and they told me that when you have a red flashing light on the charger it means the lithium battery is no longer any good. They offered to send me one free of charge. It's been several weeks and I have yet to receive it.
Jul 08, 2009 | Casio EXILIM Digital Camera
Cant charge my battery
i have same camera.. but i dont think this is a problem.. while charging light keep flash.. when it completes charging it shows u solid red light..
Dec 25, 2008 | Nikon Coolpix S550 10 Megapixel Digital...
My casip ex-s880 camera will not charge
very common issue its a bad battery you can get one off ebay for like 5 bucks
Aug 16, 2008 | Casio Exilim EX-S880 Digital Camera
Cameras Logo
167 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
