Pioneer DV 266
I plugged the DVD player to an old Sanyo TV, by Audio video out put color came out black n white, accidentally turned on progressive mode now nothing is appearing on the screen, how can 1 bring it to its original setting and solve the black n white issue.
I bought the pioneer in the phils, the TV was bought in Ireland.this might help
  • Anonymous Jan 13, 2009
    I have the same problem....do not have the manual for the dvd player and turned on progressive to see what would happen and now cannot get it back...any quick fix solutions?
  • Anonymous Mar 28, 2014
    The DVD player in plugged in and working but it's all black and white and it's originally that color
  • 4 Answers
To solve "progressive mode" or any other problem on DV-266, just reset all setting to default, as follows;
Using buttons in front panel (not from remote control); - Switch off your DVD Player. - Press & hold STOP button, and press STANDBY/ON (power) button.
Good Luck & enjoy your Pioneer again.....
Posted on Jan 28, 2010
  • 979 Answers
You have two different formats that are incompatible with each other.
Posted on Apr 23, 2008
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Tip
Pioneer DVD-400V Interlace Reset To switch your Pioneer DV-400V DVD player...
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and loosing picture, follow these steps:
  1. Switch everything off.
  2. Reconnect using the supplied video cable (standard RCA Red White & Yellow).
  3. Switch the player to standby.
  4. Press and hold the Standy/ON button while pressing the |<< button.
This resets your player to default video output, allowing you to reconfigure your HDMI settings to 1080i, and then reconnect your HDMI cable.
I hope that helps.
_____________________________________
Pioneer DVD-400V Manual Download
Pioneer DVD-400V HDMI Reset
on Jun 06, 2010 | Pioneer DV-400V DVD Player
Help my dvd is playing in black and white.
Try changing your cables or checking they are correctly inserted. If that doesn't work, try it in another TV to eliminate your TV input connector. Just a thought, but you haven't accidentally altered any menu settings on the player or TV.
Nov 24, 2015 | Pioneer DV-285-S DVD Player
Tv screen turns black and red when playing through pioneer receiver
Usually when I hear of solid colors that display on a TV, my first solution would be to change the cable. We know your DVD player is working as you connected it straight to your TV and you report no problems. I assume you are using a composite cable (red, white, and yellow) Red and White being the Audio and Yellow your video.
But since your player works...and your tv works under the same input, then the only other issue would be the output cable from the receiver or the actual composite input or output connector is faulty.
try a video game system in place of the dvd player through your receiver..if it happens again, then change the receiver's output cable...if it still persists then your reciever's output connector is faulty.
I hope this helps.
Aug 09, 2012 | Audio Players & Recorders
I have a Sanyo Cinema Progressive DVD player and the videos are playing back in black and white, rather than in color. What is the problem?
The output signal maybe set to S-video and the input connector does not have S-video capability. Change the output signal or use a HDMI cable. If the connection is via progressive cable (three leads), the colors maybe mismatched.
Apr 09, 2011 | Sanyo Cinematic Progressive Scan DVD...
Hooking up this dvd player -- I have audio but no
TRY USING THE RED AS THE YELLOW AND THE YELLOW AS RED, THIS SHOULD MAKE ONE SIDE OF THE AUDIO NOT WORK AND THE VIDEO WORK. REPEAT WITH THE YELLOW/ WHITE. TRY DIFFERENT CORDS. TRY IT ON A DIFFERENT SYSTEM. YOU MAY HAVE KNOCKED SOMETHING LOOSE INSIDE IT.
Nov 16, 2009 | Pioneer DV-343 DVD Player
I accidentally pressed progressive scan on my DV 366 player and my TV screen went blank. I can listen to music now by there is no picture on the TV screen. How do I correct it?
You will have to press the progressive scan button again, but most of the time you will have to remove any discs that are in the unit first, before you press the buton again
Aug 30, 2009 | Pioneer DV-366K DVD Player
Progressive scan, no pictures on tv
Hold down stop button and turn on standby button this will reset to normal mode.
Mar 12, 2009 | Pioneer DV-270-S DVD Player
Black and white picture
turn off you dvd player... them click on "setup" button on your remote control! them click right botton to appear "tv sys" them click "enter"... choose your tv system, PAL or NTSC.
Jan 15, 2008 | Pioneer DV-360-S DVD Player
Progressive scan
lpug ur dvd. without turning the power on press and hold the stop button then press the power button
Sep 22, 2007 | Pioneer DV-373 DVD Player
Televison & Video Logo
529 people viewed this question
Top Televison & Video Experts
Electro Med Services...
