SOURCE: Brand new Flip Ultra HD. Giving error "Check Battery Pack Chargin
check the contacts on the bottom of the pack. for some reason, the plastic sheathing covers the positve contact of one of the batteries. i took an xacto knife and cut a small hole to expose that end. after that, voila, no more charging problem. i woke up to a full charge this morning!!!
SOURCE: Borrowed a flip video to tape daughters
camcorders don't generally charge from pc's as the voltage is much higher.they won't switch on when the battery is low or i should below a certain voltage..try charging it using its charger it will probably be fine .good luck farr64[colin]
SOURCE: I was charging my flip
I had paralled problems and kept reinserting the flip into the usb port. After 6 or 7 times, I was able to get full charge.
SOURCE: Is there a special cord to charge a flip video or
hey guys! flip not turning on after charging? well, i have gotten a solution for you. before doing any of this, please read all directions. first, look at bottom and slide to unlocked key. then, gently slide off front of flip, with thumbs pressing down, to where batteries are stored. after taking out batteries, up top you will see a small and flat gray box with a mini black thing sticking out of it. take something sharp, like a pencil or pen, and press down to the back, closer to lens, that black thing for sixty seconds exactly. one minute to be exact. next, slowly put the batteries back in correctly, and put on the cover of your flip. at the bottom, slide to locked lock. wait three minutes or so. then try turning it on. after you see it works, plug it in to the computer as quickly as you can. the way you do that is by sliding metal piece down on side until a plug shoots out. you plug that in to the correct sized jack on your computer. let it charge as long as half as a day. before unplugging, eject the flip in the right hand corner on the computer screen. CONTINUE READING!! if still when you plug it into the computer after the metal box process and nothing does anything on your computer that is no good. if no boxes that say download pix or anything don't pop up that is the same. look in the bottom right corner of computer screen and maybe something is there. if not any of those thing, repeat the whole process of this paragraph over again. after doing this process a few times your flip and still not working might be trash. after doing metal box thing a few times and it does not turn on it might be trash. by the way, i am a ten year old girl in fourth grade who likes cheese, has a flip, and lives in NJ. thanks guys! i am always willing to help out others.
emma
All I did was hit the unlock on the bottom and slid the face off to reveal the battery, cleaned the contacts and put the battery back in, works fine.
All I did was unlock the slide on the bottom, slipped the face off to reveal the battery, cleaned the contacts and put the battery back in, works just fine.
