Question about Gaggia Titanium Espresso Machine
ESPRESSO MACHINE LOST POWER AND WILL NOT TURN BACK ON
  • GCHEFDRE Apr 23, 2008
    were is the internal re-set fuse located?
    were is the fuse located in the machine?
    Master:
  • 788 Answers
According to the manual here: http://www.gaggia-canada.ca/PDF/Titanium_ist.pdf there is no power to the machine. If there is power to the receptacle then the machine is faulty. It most likely has an internal fuse, you will have to dissasemble the machine to examine for a burnt fuse or any other burnt or broken component. Also, you will want to check that the power switch is working properly, open with off and closed with on.
Posted on Apr 23, 2008
  • Dean Joly
    Dean Joly Apr 24, 2008
    Not sure, most likely near the power connector. You'll have to take it apart to find out.
    Genius:
  • 1,142 Answers
Can you give the make and the model # please
  • Maanita Chadha
    Maanita Chadha Apr 23, 2008
    Try to un plug the power cable which is connect to your power surg and try to get the cable connected to the a different power outlet and you can check the fuse too which might be blow in the plug itself.
    Dont forget to rate Fixya
    Thanks
  • Maanita Chadha
    Maanita Chadha Apr 24, 2008
    You have to replace the plug head. Purchase a heavy duty commercial grade head, and take care to
    make sure you have the polarized plug properly grounded to avoid
    electrocution.
  • 655 Answers
Check out power card/adopter.
Also try to remove connction
Then connect again.
  • 2,326 Answers
Try a different outlet.
The internal thermal fuse could be damage.
How to install new switch?
Remove the back cover of the machine by removing the 2 screws on the back.. Pull the back cover off, and you would have access to the power switch on the back of the machine.
Purchase a switch click here.
SWITCH NE03 028
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
May 27, 2015 | Saeco Incanto Classic Espresso Machine
Defuser unit stuck at bottom of Delonghi magnifica coffee machine. Squeezing red buttons does not help. Cannot remove
Recycling the power resets the position of the defuser. When you turn it off, make sure you do it via the button on the front before swutching it off at the power point.
Aug 21, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
When i turn machine on and put the capsule in i press the start button and the water leak out the bottom instead of the spout
Turn the machine off with the Power button, and pump the pod receptacle latch on top 3-5 times. Turn machine back on. Ta-Da!
Jun 01, 2011 | Nespresso Essenza C100 Espresso...
Infuser is stuck at bottom of machine
hi, try turning the power on at the machine like you would normally do , then turn the power off at the machine again, not at the power point this should make the infusser pull back.
cheers
Jan 03, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The infuser seems to be stuck to the side and I cant get at the red release button on the right hand side
Put back together, turn on the machine, then turn of the machine with the power button on the machine, then turn of the power point, should be back in place to push in both red buttons, enjoy your working machine and coffee, cant find an answer for my issue
Jan 02, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
No water/coffee comes through? the temprature indicators doesnt light up?
The POWER LIGHT for the 889 is RED and located on the LEFT of the center cowling
The BOILER LIGHT for the 889 is YELLOW and located on the RIGHT of the center cowling
If you turn on the power to the unit (the INNER SWITCH on the RIGHT SIDE) the RED light should turn on, showing that the machine is powered. At that point the YELLOW light should also turn on for about 10 seconds, at which point it will turn OFF with an audible CLICK.
If the RED light does not turn on then you have a very dead machine.
If the RED light does turn on but the YELLOW light does not then you have a half dead machine.
Opening up and repairing the 889 is not for amateurs. High voltage, heat and pressure inside.
If you decide to bin the machine I would appreciate getting the drip tray from you as I have lost mine.
Graham Leach
Sep 05, 2010 | Dualit Espresso 889 Espresso & Coffee...
No power is getting to machine, power light does
Join the club. Get your money back and buy a Tassimo
Feb 21, 2010 | Keurig Elite B40 Coffee Maker
Where is the fuse on a saeco royal professional unit? i lost all the power on my espresso machine and i'm assuming the fuse is the problem but i cannot seem to locate it on the unit itself?
There is a special *amp fuse inside on the back bottom of the machine. It is next to the pump. There is a gray cover over the power filter where the fuse is ;located. You can see the power wires going into the cover. There is also a special .35maT fuse that is on the back of the power board.
Feb 12, 2010 | Saeco Royal Professional Espresso Machine
LAVAZZA ESPRESSO POINT CAPSULE MACHINE WON'T GO ON
There are two ten amp small bus fuses in the back of the machine directly next to the iec power cord. Should you need service you can call 781-393-2929. We are an authorized lavazza distributor and repair center.
Jun 19, 2008 | Lavazza Espresso Point Capsule Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
204 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
