Question about Ericsson Cell Phones
The phone doesnt turn on and when it does it goes black and white on the screen.
Hello i e mail you before about my metropcs huawei m318..this metropcs company is totally phone fraud.they have a block on my phone ..here is my phone number 1<562>219-8921 here is my esn#01807188604 this company metropcs hasn't repaired my phone or sent me a replacement phone.my phone has a lcd phone screen technical problem i have a black spot on my phone that blocks my phone from text messages or when my phone was on can't read phone numbers because of black spot on phone..metropcs is not a good cell company its been 4 long months of nothing.my cell is block and off please turn on phone and unblock it.urgent/urgent/r.s.v.p
Posted on Sep 03, 2008
AldRezaine
  • 995 Answers
SOURCE: nokia 5130: blank screen, phone doesn't turn on
That means your phone got a corrupted software installed to its memory. A hard phone reset can solve this problem. Typically a nokia symbian series phone can be formatted using this code *#7370# then the default key is 12345.
Hope this could help.
Posted on Mar 26, 2010
Testimonial: "yes, it did get corrupted by a software and I had to give it to some workers at nokia to fix it, I lost the info on the phone (except memory card)"
  • 1011 Answers
SOURCE: phone continually goes to white screen, freezes, turns on/off
dear,
white screen mean, the strip that connect to the display section to other circuitry. u have to repair the strip or get it replaced by new one if its seriouly damage alot.
i have faced this problem.
regards,
Posted on Jan 04, 2009
SOURCE: phone doesnt turn on, lights on but screen stays black
its BROD " Blue Ring of Death" try to use A2 uploader then flash FS, MAIN and CDA... if you cant then send your phone to me... i always experience BROD...
Posted on Jun 18, 2009
  • 171 Answers
SOURCE: so my main screen is
You must replace the phone flexible band
Posted on Feb 11, 2011
walesarumi
  • 6993 Answers
SOURCE: my screen on my lg
When a phone screen is blank, has a white screen, etc, there are three things that could be the cause;
  1. Bad/defective screen and the solution is screen replacement
  2. Software/Virus problem and solution is to flash the phone
  3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
I hope this helps.
Good luck.
Posted on Apr 23, 2011
Blank white screen when opening or closing
try doing a reset settings or master reset on the phone, since this is a device issue if it doesnt work then you will need to get a replacement phone thru your provider
Mar 14, 2010 | Samsung Propel A767 Cell Phone
Black And White Screen When I Turn My Fone On
The black and white screen problem can be fixed on your own for free by using the free Sony Update Service. It fixed my phone when it was doing the same thing as yours.
Jun 19, 2009 | Sony Ericsson Walkman W810i Cellular Phone
The screen doesnt turn on
either your lcd is bad or your flex cable,,just disconnected and pulg into good working one and you can tell,,,
May 02, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Phone continually goes to white screen, freezes, turns on/off
hi insane,
ur phone needs to b re-flashed. i.e its file system is corrupt. if u r not a techie guy then better take it to an repair center. otherwise chk this site out: mobilejunkies.net
this will work it out. good luck!
Jan 02, 2009 | Sony Ericsson W300 Cellular Phone
Z610i Lets out beep but doesnt turn on
Sounds like the device is defective. I would have the battery tested before deciding to replace it.
Jul 06, 2017 | Sony Ericsson Z610i Cellular Phone
Nokia 6288
Scan your memory card for virus....formatt your phone *#7370#.
Use McAfee anti virus.
Jul 21, 2008 | Nokia 6288 Cellular Phone
Cell Phones Logo
288 people viewed this question
Top Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you an Ericsson Cell Phone Expert? Answer questions, earn points and help others
