Question about Lands Phones
Carnt get hand sets to work with base unit - Lands Phones
  • Warren Jul 31, 2008
    handset not ring, no intercom working
Can't connect my second handset uniden 5.8ghz
Posted on Jun 19, 2008
My base unit unit keeps flashing 8-88, and the hand sets all say searching
If there is an error code with an E followed by a number or "88" displays/flashes it would be an internal issue in the base unit. Uniden does offer a limited 1 year warranty (Covers Manufacture Defects ONLY, if caused by a power surge or power outage or any other type of damage that is not a Manufacture Defect this is not covered under warranty) off the proof of purchase. The proof of purchase is required for warranty service.
May 10, 2015 | Uniden D1484-4 Dect Cordless Phone With...
I have two KXTG 5633 Panasonic base units and 4 KX TGA 560 B expansion hand sets. Of the 4 hand sets only one is working properly; I cannot get a dial tone on the other three. They were all working fine...
On the base unit: Press {SELECT} until the desired extension number (H1, H2, H3, or H4) is displayed on the base unit, then press and hold {CALL} until the CHARGE indicator flashes.Handset:Press {OK}, then wait until the handset beeps.Also check if there is a reset button or an option in the menu of the handset menu that enables you to reset it to factory defaults then follow the above steps.http://service.us.panasonic.com/OPERMANPDF/KXTGA560-MULTI.PDF also this could help or this http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
Have a nice day...
Oct 02, 2011 | Cell Phones
I have just inherated the at&t e5634b phone system. I have replaced the batteries in the hand sets. As per the manual I have de-registered each hand set. The problem is that when I register the...
This problem can be caused by the following, A bad battery, (which you say you are all new). A full base memory and a Faulty main base unit
This main base unit can only expand to four handsets and no more. If the base unit has been reset then the assigned numbers for each handset would begin with " handset 1" if they show any other number when reset then it would not have been reset..To re-set main base you will have to
De-Register All Handsets
Unplug the power supply from the base unit then Remove all handsets from the charge cradles and base then Press and hold the PAGE button on the base.
Plug in the power supply again while pressing the PAGE button, Continue pressing PAGE until the IN USE and CHARGING indicators are lit. (this could take up to 10 seconds)
Release the PAGE button All Handsets will display "enter base id".
If this does not solve your problem then you will have to replace the main base
Apr 20, 2017 | AT&T E5634B Phone System w/ Caller ID
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Jul 22, 2010 | Doro DECT 540 Cordless Phone
I have a Pansonic kx-tga270s that is registered to a base I do not have. Is there a way to deregister it.
you dont need to deregister it if you have not registered all 8 hand sets with your base unit. Just register the new one and the base will assign a new # for this new. I you had registered 8 hand sets with your base already, you need to remove(deregister0 one handset from your base(it can take only upt 8).
If it still not registering please deregister as follows:
on the base unit, press program, them mute, then enter 335#, then enter the handset number you wish to deregister.
after deregistering try to register your new hand set.
Nov 19, 2009 | Panasonic KX TGA270S Cordless Expansion...
I have the panasonic kxtc1175bxb cordless phone pair the handset
sorry, it seems that they have no manual for this model online yet. however, the procedure to reset handsets might work if you go to page 35 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf") good luck!
Feb 04, 2009 | Panasonic KX-TG1033S Cordless Phone
Searching....
The problem of searching.....
After trying all the technician's suggestions had failed; I disconnected the base to return it to the store for replacement. Then I decided to try disconnecting and reconnecting power and phone line, placed handset back on base and the phone reset itself and is working fine...
Recap:
Disconnect power and phone line from base for about 30 seconds and reconnect both power and phone line to base and place handset back on base; it should reset...
Linda
May 05, 2008 | Uniden DECT 6.0 Cordless Telephone...
No Link To Base Unit
I am having the same problem!
Mar 10, 2008 | Panasonic KX TC1743B Cordless Phone
The phone ( sub-unit) links to the base on and off from time to time. How can I do ?
Sounds like the RF (radio frequency) module may be bad. If your battery is really old it could also be the problem, especially if the problem is more likely to happen after the phone has been off the charger stand for some time.
May 02, 2007 | Panasonic KX TGA270S Cordless Expansion...
Lands Phones Logo
125 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
