Question about Kenmore 44072 Front Load Washer
Fabric softener Hello, my front load washer does not add the fabric softener to the load, I've cleaned everything the best I can, Any ideas, thanks
  • KMACK50 Feb 25, 2009
    FABRIC SOFTNER WILL NOT DISPENSE. I HAVE MATCHING DRYER STACKED ON TOP OF WASHER. I'VE CLEANED THE INSIDE(WHICH GETS VERY MOLDY). THE LIQUID DETERGENT DISPENSES BUT NOT THE FABRIC SOFTNER. ANY IDEAS?
  • 101 Answers
If you lift the top of machine with a flat head screw driver . just push in and lift the top ,you will see the hole which is connected. replace the hole. hop this information could help you
Posted on Apr 23, 2008
Bleach dispenser
Hello friend, I appreciate your post!
I understand your having an issue with the bleach dispenser of your Frigidaire front load washer. I would like to ask a couple of additional questions to better assist you. Is it not dispensing bleach? If you add fabric softener does it do the same thing? Finally, what is your model number so I may be able to proceed further? Normally you can locate the serial tag (which lists your model number) on the upper front of the door frame. Thank you for the post and I look forward to assisting you. -Matt
Jul 22, 2014 | Frigidaire GLTF1670A Front Load Washer
I put dishwashing liquid soap into my front loading washing machine, UGH!!!!! What should I do? The suds just won't stop!!!! Help
Thanks for choosing FixYa and welcome. As you already know, this is a bad idea. Now, there is probably soap in the entire system. After a few runs they should clear up. I would suggest cleaning the tub out with a towel. I would say they are probably in your pump also. You will probably need to clean your pump out also. It is located inside the washer so it involves a little bit of work. Clean out your dispenser as well. Try not to use water. Just use a towel.
Jul 12, 2011 | Washing Machines
I would like to know what laundry detergent and softner to use in my front load, and the right amount to use. I buy the H E products and some of them are really sudsy in the wash sink and I have this awful...
You should use HE detergent following the directions for that detergent. You can add liquid fabric softener. Make sure to fill the appropriate compartment to the Min line if you are doing a small load.
I've never used a washer that drained into a sink (always had a stand pipe). However, I suspect that the gummy residue is the excess softener that was removed in the rinse cycle. Try rinsing the sink with hot water after a laundry. This is part of the procedure to clean the inserts and detergent/bleach/fabric softener drawer when you get a build up in the drawer. In the future, use less fabric softener in the washer. Alternately, skip the fabric softener in the washer but use a dryer fabric softener.
The manuals for most Frigidaire appliances are available from http://www.frigidaire.com/manuals .
The direct link for the manual (in English) for the is: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134609000een.pdf .
I hope this helps.
Jun 05, 2011 | Frigidaire ATF6000ES Front Load Washer
The fabric softener and bleach trays will no longer feed into the washer they stay full. Any ideas?
Just wondering by taking the top off & cleaning it would this solution be the same if the fabric softener tray has water in it after washing a load of clothes?
Jun 27, 2010 | Frigidaire ATF6000ES Front Load Washer
Fabric softener will not drain
Try cleaning out ..this should cure . the other thing that can cause this is a faulty solonoid valve as some machines have a seperate valve for this action....
Nov 25, 2009 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener wont drain
REservoir Blocked.
Fabric softeners are abit of a nuisance in many respects.. I would rather stop the machine and manually add it after the first spin.
Why does everything have to be Automatic or nothing?
Oct 24, 2009 | Frigidaire Affinity ATF7000E Front Load...
Fridgidaire front load will not empty fabric
Hello, W/D here.
There are a couple of reasons why the fabric softener will not dispense. If everything else dispenses properly (detergent and bleach), then I would suspect a bit of plugging. If the softener remains in the dispenser, the water valve above the tray may be sticking. You'll have to get the top up to check it. If there is water in the tray, or some water/softener, then you'll need to look at the overflow cap. Here's how that works: Your dispensing trays for bleach and softener have a raised tube built into them, and each is covered with a loose fitting cap. When water is let into the tray, the level rises under the cap until it overflows, creating a syphon. The softener is literally pulled from the tray, and chased by the water. When the water stops, the tray level continues to drop, until air gets into the cap, breaking the syphon. The cap can be removed and cleaned. Sometimes the tray has to be removed first. Theres a catch towards the rear of the tray.
Best regards, W/D
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Moldy smelling clothes
First, clean your washer with one of the front load washer cleaners on the market. (Affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, or Tide front load washer cleaner) Use the longest, hottest cycle your washer has, with no clothes.
Second, rewash the smelly clothes with the heavy wash cycle and a second rinse option, using no soap or fabric softener. This will remove the soap and/or fabric softener build up in the clothes which is causing the smell. Third, begin using one to no more than two tablespoons of HE soap per load, and not more than 1 teaspoon full of fabric softener if you use it. This is because top load washers used up to 45 gallons of water per load, and your front load machine is only using about 12 gallons total. If you are washing a load of bath towels (which were only used to dry off your clean body, not wipe up the floor or something like that) they are not really dirty,...... for washing "clean" towels, don't use any soap, and of course never use fabric softener on towels.
Jul 01, 2009 | LG WM-0532HW Front Load Washer
Fabric softener won't dispense
Have you tried thinning the softener with water? It's what I used to do on my older washer, it wasn't the new Duet, but it seemed to help. Hope that helps. (PS I don't use softener anymore as I have developed a terrible skin allergy to these newer longer scented softeners! )
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Remove the fabric softener compartment for cleaning
open up and on the left side toward the back you see a little tab push it down pull out the dispencer
Mar 02, 2008 | Bosch WFMC 3200 Front Load Washer
Kenmore 44072 Front Load Washer Logo
55 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
