Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Replaced GE SmartWater filter in my GE refrig and water wil l not flow thru it,why?
How to get water to flow thru new replaced GE SmartWater filter?
  • Anonymous Mar 30, 2014
    loud knocking sound when facet is turned on; air in line or ?
    Problem Solver:
We replaced the water line to the refriderature. It was plugged by a coroded copper sleve.
Posted on Apr 29, 2008
    Problem Solver:
Replaced clogged water line on back of refrid,
Posted on May 01, 2008
Ge smartwater filtration system has slow moving water
You have to prime air out of new filters. Also if you have a reverse osmosis water system, your water pressure may not be sufficient.
You may have to bypass the filter. Most fridges come with a plug that will fit where the filter goes. good luck
Dec 27, 2013 | GE GXRLQR GE SmartWater Inline Filter...
In replacing a GE SmartWater filter on my GE profile side by side refridge the water will not flow thru new filter, why??
first thing is to make sure it's installed in proper direction. Those have arrows or other marks to indicate inflow/outflow. Please check that first.
Apr 23, 2008 | Refrigerators
After replacing the cartridge, the water flow is extremely poor. After calling GE, I was told I may have a bad filter. Hope not at the price per filter they charge. Is there any other solution? Is it...
The GE GXRLQR is the correct *replacement* filter for the following "Smartwater" single stage filtration and exterior refrigerator icemaker systems:
  • GE GXRLQ
  • GE GX1S50F
  • GE GQ1S50F
This filter is rated for only 750 gallons / 6 months of use (typical fridge with ice maker & water service). Most home faucets will deliver about 6 gallons / minute which roughly translates to about 2 hours of running water.
The GE FQSLF works with the following for the following Dual Stage Under Sink filtration systems:
  • GE GQSL55F
  • GE GXSL55F
Because there are 2 filters, they will last nearly 2x as long as the GE GXRLQR. and would likely be better suited to serving a faucet which will pass much more water than a fridge ice maker & chilled water dispenser would.
The real question is: Which GE filtration SYSTEM (not filters) do you have?
Sep 09, 2013 | GE GXRLQR GE SmartWater Inline Filter...
Very slow water flow into ice maker and almost no flow from water dispenser. Replaced filter, did not fix problem.
HI if your using a saddle valve to connect your water to to main water line, this is the problem either switch to a regular T-reducer or try to drill the hole bigger in the saddle valve, those wil restrict the flow to your refrigerator.
Sean
Mar 28, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
GE smartwater filter (model GXRLQR) stopped working...help!
These replacement filters (GXRLQR) are FLAWED straight out of the factory. The problem is in the 2 little "teeth" nubs that stick up near the center circle of the filter. When the filter is twisted and inserted, these teeth push up on a tiny black spring loaded valve in the body of the filter, alowing water to pass through up and out the spigot. The flaw is that the "nubs" are too short and do not push open the spring valve far enough, reducing flow to a semi-trickle, even with a brand new filter. GE seems to think this is not a problem.
Solution=stick a $0.25 garden hose rubber washer in the top of the filter and screw it in. You may have to try a few times to get it to work and seat properly. When it works, you'll immediately get a nice super flow of water. Better than upgrading to a $200 filter system recommended by GE...
May 06, 2010 | General Electric GE SmartWater Household...
My GE GSS25VFPAWW side by side refrig. wil not despense water.
I turned off the unit for an hour with the door open and the ciller tubes thawed. the water started wotking again.
Dec 26, 2009 | GE GSS25VFPWW Side by Side Refrigerator
Low water pressure is diminished after replaced 2 filters in a month. plumber tested to see if water is fully flowing.
Does this mean that you are now having the right pressure? Since the filters are changed, water should
now flow. Is it all systems go?, that is assuming that
your pipelines are not clogged.
Nov 05, 2009 | General Electric GE SmartWater Household...
No flow after filter change.
G E waterfilters , can be bad when new (all , not just G E ). Put your old one back in , if water flow was fine , and you replaced just because the light came on . Or , use the plastic bypass piece , which came with the refrig , when new . The replace light , works off time and/or usage times only . If you have good water flow and the cubes are normal size , don't change the filter when the light comes on , just reset the light . All "filter" companies , have found the way to sell more filters , the light on dispensors .
Sep 11, 2009 | GE Refrigerators
Slow water flow from GE SmartWater under sink water filter.
I solved the problem! The system's manifold (the plastic base you put the filter in) has small black conical shape button. When you tight the filter in, one of the two small triangle-shaped cams (located close to the filter's central hole) pushes the manifold's button, and this opens the water flow. The problem is that the cams are too low and do not push the button all the way in. Take a pliers and squeeze (not too much!) the cams, so they will raise a little: it will be enough to push the button to open the flow completely.
Mar 11, 2009 | General Electric GE SmartWater Household...
Refrigerators Logo
971 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
