Sharp Liquid Crystal TV - Flat Screen - 1.5 years old
One of my main channels and a few others are randomly switching to spanish language without any menu changes. They are all set to English and have never been set to Spanish. If the main show is doing the Spanish thing - the ads are in English or vice versa - its only doing it at prime times in the evenings.
  • 146 Answers
Go into the menu and under AUDIO and make sure that the sound is set to STEREO, and not SAP (second audio program). If you have a separate setting for SAP then shut it off.
Posted on Apr 23, 2008
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Hello! I have a Sharp Liquid Crystal TV (37" display) and my menu options, specially the picture menu, is fixed. can you help me "unlock" it? Model # LC-37G4U
If the AVC System is switched on but it does not appear to be operating correctly, it may need resetting. In this case, press RESET, shown in the diagram, lightly with the end of a ballpoint pen or other pointed object. This will reset the System as shown below. • AV MODE resets to STANDARD • TV channel returns to initial channel setting (Air:2ch, Cable:1 or 2ch) • Twin picture resets to normal • Audio setting initializes • Dolby virtual resets to Off • Image position initializes
Nov 07, 2015 | Sharp Televison & Video
Sharp LC46SB54U Liquid Crystal T.V
This screens are all but impossible to replace.You only have a couple of options. 1. Buy a replacement screen for the television manufacturer 2.Find the same make and model of television with the screen intact and purchase it. This can be done by watching websites like e-bay and craigs list for these items. You can go to the websites and use their search engines with the brand name and model number tofind the televisions or the parts that are for sale. If you can find the part number of the lcd screen. You can try to locate the lcd screen maker and buy the part from them. By far the lowest cost alternative is to find a television with other problems, that is not repairable and buy it and use the parts. You can also look for it in local newspaper ads and yard sales. I hope this information helps you with your problem.
Jun 06, 2009 | Sharp LC46SB54U 46 in. LCD TV
The Set-up button doesn't bring up a menu.
I think the fastest way to fix this problem is to press the SYSTEM RESET button on the back of the TV. It will restart the TV and go through the INITIAL SETUP again and you can do the language change and channel search.
The SYSTEM RESET button should be on the right side on the back. It's small button below the "10101" RS232C port.
Apr 21, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
How do I get my lg tv back to english on one channel
hi..It's simple,go to settings there u will have a
option called language.In that u select the
language as english.This will solve your
try this..
thank u..
rate me..
Feb 10, 2009 | LG 37LC7D 37 in. LCD HDTV
Wii Controller into TV - - Very Bad
An LCD TV, from front to back, consists of these layers:
protective film - <1mm thick
liquid crystal cells - <1mm thick
charge screen - <1mm thick
backlight panel - 5-10mm thick
metal heat spreader - 2-5cm thick
controller board - 1mm thick
Your son most likely damaged the liquid crystal cells...
Unfortunately unlike normal TVs these are precision assembled, and there isn't much you can do to fix it.
It is possible to replace the screen, but it involves replacing the entire unit, from protective screen right to controller board. In other words, almost everything except the plastic case.
Unfortunately I think the tv is busted permanently, and it will cost more to repair than to replace.
Dec 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Model LD 200 EMB
This may sound stupid and not help anything but I would change the batteries in the remote first; that's the simplest possibility.
What the set is doing is selecting a function, the first is 'Auto tune' during which the set is looking for usable channels on the 'off air' (antenna) input. I suspect you have cable or satellite meaning that there will not be any signal at the antenna input and the set just looks at each standard channel frequency and then gives up.
The language thing; this is curious but also a sign that it has switched to the menu mode where you also need to be if you want to do a channel search on purpose.
If the remote is not at fault, then it is an internal problem you will not be able to repair on your own.
The circuitry that interprets the received infrared signal from your remote has started producing noise or the output from that after a decoder, has gone noisy and is just choosing functions on its own.
The blue screen is what most sets use as a default when no signal is found at any input.
Unfortunately. Emerson, RCA, Zenith and a few others are US names we once trusted but now have been acquired by Asian manufacturers who are building junk with labor pulled from the fields to assemble high tech gear.
Aug 27, 2008 | Emerson EWL20D6 Television
No sound on four channels while all other channels sound is fine.
You most likely have the SAP1.gif mode activated. Look for a button on your remote or an item in the on-screen menus of your television1.gif called MTS or SAP. You want to set this to "Main" "Normal" or "Stereo" (or even "Mono") mode to hear the regular television sound.
If it is in SAP (Secondary Audio Program) mode, as I believe yours is, you may hear no sound or a different audio program. Often this is a translation to another language, such as Spanish, and other times (notably with PBS stations) it is an unrelated audio (often music) feed. On some stations there may be no sound at all with the audio mode set to SAP.
Feb 14, 2008 | Sharp Aquos LC-13SH3U 13 in. EDTV-Ready...
Sharp LC37G4U Liquid Crystal Flat Screen
If this also happens on a DVD or video recorder, you could have a power supply issue or maybe a problem with the back light circuit. The best advice would be to take the TV back where you purchased it, if it is new. If it is not a new set, take the TV set to a repair shop for an estimate. Good Luck
Jun 20, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Some channels have no sound some are in spanish
With your remote, go into the menu, find the audio setup and click off the SAP. Thats the Second Audio Program. Some Broadcasters send a second lanquage along with the regular audio. Someone must have been looking around or playing with the remote and turned on the SAP.. Good Luck PS please do not forget to rate this thread
Oct 18, 2006 | Orion STV2763 27" TV
Televison & Video Logo
433 people viewed this question
Top Televison & Video Experts
