I have a new monitor that requires a resolution of 1440x 900 pixels and my computer requires a newer driver. How may I obtain one? Thanks Ben Leightman leightben@bellsouth.net
    Guru:
  • 1,342 Answers
Go to your PC manufacturer's website and do a search for your model then look for downloads and drivers.
Posted on Apr 23, 2008
I need to have the resolution set at 1440 X 900 for best viewing. I don't have a clue how to do this. Thanks.
Hi
Please do the following
1) Switch on your PC
2) Right Clickin the middle of the dekstop and click on properties
3) This will open a display properties window, at the top there will be a tab called settings
4) In this windows half way down there will be a option entitled screen resolution, this slider can be pushed to the left or right push to the left until the figures at the bottom read 1440 X 900 pixels
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 17, 2010 | eMachines E17T4W 17" Monitor
Connect VA1912w Monitor with DELL Laptop
I don't think it is a problem with the monitor or its driver.Please adjust the monitor settings on Windows by Right click-Properties-settings-Screen Resolution-1440*900.Now check whether you are getting the native resolution.
Feb 04, 2010 | ViewSonic VA1912w 19" LCD Monitor
I have dowloaded drivers for samsung syncmaster P2050 but still cannot get the resolutions to adjust
Your monitor doesn't require any special drivers to work properly. If your monitor is a widescreen monitor, your video card needs to be able to address the monitor's resolution, not the other way around. You'll need to either update your video card's drivers to obtain different resolutions, or you'll need to replace your video card with a newer one that does widescreen resolutions. Good luck!
Jan 14, 2010 | Samsung P2050 Monitor
Acer 22 aspect circle, not elipse
You'll need to change your resolution to one of the below to get the correct aspect ratio for a wide-screen display.
1440 x 900
1600 x 900
1600 x 1024
1680 x 1050
You will find these settings in Control Panel / Display / Advanced. If none of the above are options you will need to obtain newer display drivers.
Please let me know if this helps or if I can be of further assistance. Thank you.
Sep 19, 2009 | Acer 22" X223w LCD Monitor
Resolution problem! 1440 x 900 resolution is not even listed anym
I would recommend that you go into Device Manager, then locate your Display Adapter, and uninstall it completely. Once it's completely uninstalled, reboot your computer. When it comes back up, it should start out around 800x600, then Windows will attempt to install the default Intel driver. When it does this, it may restore your driver to the original state. Good luck!
Jun 16, 2009 | ASUS Computers & Internet
Have a new 23 inch samsung monitor that requires res 1920x1080
The problem is the cable connection to the video card.
When using the DVI output of the FX 5500, the maximum screen resolution that you can select is 1280 x 1024.
But, if you use the Analog (VGA) output, the card will support resolutions up to 2048 x 1536, which should be ok.
Apr 23, 2009 | XFX GeForce FX 5500 Graphic Card
Screen resolution reminder.
go to the control panel double click DISPLAY then select setting then select 1440x900
Jan 09, 2009 | E-Machines eMachines Desktop PC
Chimei CMV 938D 'Out of range' error message only when using DVI Connector on specific resolution and color depth
I know this sounds obvious but- I had the same problem, and turns out the cord want plugged in quite properly at the back of the monitor. This may not fix every problem, but, I suggest you check the cord pligged in at the back of the monitor is firmly in there and restart, then if you still get the problem, contact the company.
Jul 21, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Computers & Internet Logo
David Payne
David Payne
