Keyboard does not seem to be picking up the antenna
    Problem Solver:
  • 30 Answers
Try reconnecting the keyboard by pressing the reconnect button underneath the keyboard and reconnection the attenea as well.
Posted on Apr 23, 2008
I only get a wifi connection when I am next to the wifi hub. I lose the signal when I move 4 meters from the hub. Other laptops pick up the wifi without problem. I have tried using the zenbook on main
It's may be the laptops Antenna? Wire broken, pinched, damage, connection loose. The Antenna is usually behind the monitor, wires run from the wireless adapter through the hinges and attach to the antenna, Maybe a loose connection on the Wireless adapter itself? Sometimes you can access through a bay door on the bottom of the laptop, sometimes you have to disassemble the laptop/keyboard, depends on the Asus Model. Have you connected a Ethernet cable?
Jan 08, 2013 | ASUS Computers & Internet
Can't pick up am channels
Do you have the AM antenna hooked up? FM and AM need a separate antenna for each. An AM antenna is usually a "loop" antenna, which is a wire coiled around a frame.
Dec 23, 2012 | Audio Players & Recorders
I can't seem to get any reception, just noise.
It mostly depends on your antenna location and how far away you are from other radios. The receive gain can be turned up in most radios. I do it here all day long. dodgem250.com
Apr 09, 2010 | Midland 4001 40-Channels Base CB Radio
I have a wireless micro innovations keyboard that seems to be locked. Any idea how to unlock it? I wiped it down today and has not worked since. I've changed the batteries; shut down my computer;...
This could be bad or just annoying depending on how you wiped it down.
There should be a monitoring utility that will let you choose settings and see what the keyboard batteries are. You should be able to see if it is finding the keyboard. This should also be where you can unlock the keyboard or use a security code.
There should also be a reset button or connect button along the bottom of the keyboard as well as one on the antenna. Press the antenna first then the keyboard button. The lights on the antenna should flash. As well when you press caps lock or numlock a light should change on the antenna.
One thing to check is that the antenna connector is plugged in. On mine it comes loose just by walking by it. Just needs a push to make sure its inserted and hasn't come loose.
If none of those get your keyboard back then it may be that you damaged the keyboard.I would try leaving it near a heating grate so that the warm air blows over it for a day or so. It may be enough to dry out the inside enough to work. Past that the keyboard may be repairable but you would have to find someone to fix it and you would need to check that cost against replacement.
Nov 01, 2009 | Micro Innovations KB1045LSR Keyboard
Can't get my convertor to pick up convertor can not find a channel it say to make the ant. is connected. I have done this. dtt901 zenith converterbox
it seems like you need to upgrade the antenna you are using. not all analog antenna will work on the new converter boxes.
Sep 10, 2009 | Zenith Analog to Digital Audio Converter
VIORE PLC7V95 7'' portable TV, cant get channels when scan
I notice that on mine, the positioning of the included tv antenna is very, very, very finicky. I also don't know how to "add" a new channel other than to hook it to the big house antenna and pick "re-scan" (or auto-scan or whatever it's called).
So I think your best bet is to pick a better antenna or know that even the tiniest fiddling with the antenna makes a diff. Sometimes, I even have the antenna horizontal (using the magnet) to get the good reception on a given channel. Seems like a hassle except that what should I expect from a tiny antenna....
Jun 15, 2009 | Televison & Video
Wireless switch
Here is all I know about Compaq Presario wireless switches. Sorry, but w/o a model I can't be more specific.
Compaq Presario, Model not specified - Button on the Back
C304NR - Button on upper right above keyboard deck, Blue is enabled
CQ Series - Button above the keyboard (antenna icon on button) next to power.
** CQ50-107NR (Conflicting reports on this model show:
Button above keyboard (antenna icon on button) next to power or lighted button below space bar that turns the touch pad on/off.
M2000 - Button above the keyboard (antenna icon on button)
Dec 11, 2008 | Computers & Internet
Not picking up channels.....
is the antenna gold or chrome? I know that if it gold they dont work as well.
Jun 05, 2008 | Radio Shack Pro-96 Scanner
Internal antenna
It sounds like the TV justs has a insufficient internal antenna system. If you can put an external antenna on this sytem do so just to test it.
Sep 21, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Computers & Internet Logo
David Payne
David Payne
