Question about Dell E173FP 17" LCD Monitor
Blinking green power on
I have tried hooking it up to another CPU at school and it just flickers a little and the green light blinks slowly. Things I can try?
  • 1 more comment
  • Distressedma May 02, 2008
    Monitor went black while system was running - now the power button goes on and off sporadically and faint flashing - no visuals though - even when i turn off system - still flashes. Tried shutting down, unplugging- replugging etc to no avail- cannot access cd info becasue no visual on monitor
  • CVpara Nov 25, 2008
    Seems to be very common, especially with this monitor. It probably is a blown capacitor. Hey it's broke anyway, and I have already bought another, so I may try my hand at fixing it. I fixed an MP3 player that no one thought I could. : )
  • parkjoony213 Nov 27, 2008
    I have the same problem, is there a way of fixing it myself? Plus which parts are needed?
This is called a "power blink" and is associated only with the monitor, very common problem--blown capacitor or transformer.
Run a search online, if you are an electrically incilned person u can get it fixed easily. If not, get it repaired cheap. dont get ripped off
Posted on May 13, 2008
  • lijinj May 13, 2008
    correction-it should read transistor not tranformer
Ive had the same problem. the guy above is an idiot, he doesnt realize that its not the computer, its the monitor. it does it without a cpu attached
Posted on May 04, 2008
  • 106 Answers
1. remove your RAM and clean it and re fix it on motherboard if its just that problem it may come up.
2. try other RAM from any working PC to ensure your RAM is serviceable.
Posted on Apr 23, 2008
  • SUHEL KHAN
    SUHEL KHAN May 05, 2008
    dear Mr Guest...
    i guess u should register urself here and start giving solutions also because what i thing you are quite a knowledgable person...dear what i told is the criteria when you want to check the monitor attached with a PC and the symptom is what he explained earlier..anyway what you will do without attaching a monitor to CPU? huh?
    any way here is the solution to your problem...
    just try out your PC with a PCI VGA card because what i could make out from very less hints is that your Onboard VGA has gone unserviceable...enjoy...
Samsung TV not turning ON. My email address is prk Please help... Much appreciated.
Its power supply I will tell you how to fix you need to get few things first
Jan 29, 2016 | Samsung Televison & Video
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
Ibm x3400 is not powering on green led blinking continiously
Hello here is others with the same problem:
http://www.ibm.com/developerworks/forums/thread.jspa?threadID=397434&start=15&tstart=0
It looks like the power button is failing.
The fault could also be the mainboard.
Try also to talk with a autorished dealer or a repair shop.
Good luck
Dec 15, 2012 | IBM x3400 Server
Hp l1906 LCD MONITOR SCREEN WONT DISPLAY. power lcd green light keep blinking. Any solution? thx
It is possible that the video card in cpu is bad, try hooking up another monitor to the cpu (computer) if you have one that will let you know if it is the monitor or the computer video card, Could be as simple as the driver is missing.
Feb 01, 2010 | HP L1906 19" LCD Monitor
Screen only flickers, power light blinks slowly
Need to change or repair monitor at this stage.
Sep 07, 2009 | Computers & Internet
Sony VAIO VGC-RB42G - No Power; Blinking green light on power
Try a different known working power supply on that computer, the green light on the power supply should be constant and not blinking. The green light on the motherboard shouldn't be blinking either but if its not getting the right voltage from the motherboard then it will blink as well.
Get a different power supply and see what happens. At that point the power supply green light should be constant, if its not then your motherboard is faulty at that point, if yout the green light is blinking on your motherboard, if both are constant then reseat the memory and CPU and only have the power supply hooked up to the motherboard and not to anything else.
If you still can't get video then at that point you know the motherboard is definitely bad.
Aug 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
Dell flat screen started flashing, green light was blinking then screen went blank and green light is on. Tried unplugging etc...time for a new one?
No. It is not a Flat Screen issue. It is a CPU issue. You CPU is not sending signal to your flat screen so the green light is flashing. Try to:
1. Reset OR
2. Unplug the CPU case, Open the CPU, the interchange the RAM modules, OR
3. Same with step 2 but unplug and then plug back in all expansion cards like audio, video cards, etc.
It seems that your system needs discharging from a frozen state.
Regards!
Jul 26, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Since it was droped our Nintendo DS Light does not turn on. Yet the green light (the power indicater) blinks once. whene you charge it the charging light blinks. and that is about it.
your going to have to get a new ds probably. See if you can get it to power up with just the power adapter hooked up. If you can get video then hook up the battery and see if it charges it up properly and that the battery keeps its charge. If it can't then try another known good battery and see if it can charge and run off the battery. If it still can't then the motherboard may have been cracked when it was dropped.
Jul 05, 2009 | Nintendo DS Lite Console
No sound, or picture, just replaced lamp and it work for 2 min...
CPU(Central Processing Unit) I.C(Integrated Circuit) of your TV needs to be reprogrammed or come to worst needs to be replaced (if the CPU I.C. part number is available in electronics parts store) by a qualified electronics service technician... hope this help ;-)
May 24, 2009 | Mitsubishi Televison & Video
Dell E173FP 17" LCD Monitor Logo
304 people viewed this question
Alun Cox
