Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Ice maker won't make ice
Water dispenser works fine, there is no water coming from the water inlet valve and no water in line going to the ice maker.Swithed plugs from the water inlet valve to make ice maker act like water dispenser but not water came out. Do I have a bad water inlet valve or do i have a bad control module?Control module gear does not move also.
  • Anonymous Apr 27, 2008
    My water maker works fine but there is no water going into the ice maker. The tube is not frozen or clogged as we have inserted a plastic line into it with hot water and still nothing the fridge is 3 years old.
  • Anonymous Mar 21, 2014
    The ice tray does not refill with water.
  • 145 Answers
It sounds like the fill tube coming through the freezer wall is frozen shut. Need to carefully take a hair dryer to it then recheck with wire swap. If you turn i/m off for a couple hours then back on you should be able to watch the fingers go around. If so you module should be good.
Posted on Apr 23, 2008
Fix icemaker
Start at the water valve at back of unit and work your way to the ice maker. Make sure the hose at the back of the frig isn't block. Also that the arm on the maker is down and in the on position. If all this checks, then go back to the solenoid that turns the water on and off to the ice marker.
Jan 03, 2015 | Refrigerators
My ice maker quit making ice the other day. I finally got under there and checked everything out and it all seems ok. The problem looks like there is no water coming in from the supply line. Why would...
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
When your ice maker dumps and refills with water it will come out the water dispenser with the wires swapped. If it doesn't then I would have to blame it on the solenoid.
If the lines are the same size you can also swap them around to do this check.
Water inlet Valve
You can disconnect the line coming out of it and try the water dispenser to see if the valve is working. If it's getting power it should click when you try it and water come out.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 18, 2011 | GE Profile Stainless Bottom-Freezer...
Water is not getting to the icemaker. however, it is dispensing at the glass tap
Water inlet Valve
Dec 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker will not work. Water is coming into the back of the refrigerator and water dispenses out of water dispenser. But no water will go to the ice maker.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 23, 2010 | Maytag MSD2651 HE Side by Side...
The water dispenser and ice cube maker stopped working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The icemaker is not filling with water to make ice cubes. The water dispenser woorks fine. Any ideas?
Mar 21, 2010 | Refrigerators
Auto Ice maker in Whirlpool fridge, not producing ice. I suspect the water feed line might be frozen since it was working fine two days ago. I haven't heard the water fill and the tray is empty.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Oct 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leak from ice dispenser line
hi..
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
Ice maker goes through the process but no ice is produced water
If you're not getting water to the ice makerTry swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
A strainer before the inlet valve can also get stopped up restricting flow. ice maker
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser leaks, ice maker won't make ice. Hve disconnected line at bottom front, and tried blowing out the lines, no help. Model EDQ22DQFNX00
Jul 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
161 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
