Question about Lands Phones
Hi, Ive got a BT Contour 100 Payphone, but there is no dial tone or display. Cheers
  • james hudson
    james hudson Sep 27, 2017
    It will be a flat battery check out my article on how to make your payphone run on 3 AA batterieshttp://www.fixya.com/support/t3349085-fi...
You need to dismantle phone and replace Varta CR1/2AA 3Volt lithium battery. Dismantling is easy enough but you MUST lay out the screws etc so they go back in the right place, particularly the one with the two nylon washers underneath the head.
Posted on Jun 15, 2009
Hi
If a BT Contour payphone has no dial tone or display it usually meams that the internal, fixed lithium battery has failed.
We have repaired many Contour payphones by removing the battery and modifying the payphone to run on standard replaceable batteries.
If you replace the lithium battery with another one, you'll have the same problem again.
If you need more info. please see our website: payphone-services.com
Posted on Jul 08, 2009
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
It will be a flat battery check out my article on how to make your payphone run on 3 AA batteries http://www.fixya.com/support/t3349085-fitting_new_battery_bt_contour_payphone
Posted on Sep 27, 2017
After a bad storm now have no dial tone on phones, cannot make or take calls,
if you have more than one phone, unplug them all from the phone line then check one phone at a time plugging it in check for dial tone. if doesn't get dial tone unplug from phone line then try the next. I had one get zap and it stopped all phones from working. soon as bad one removed the other phones worked
Feb 08, 2016 | BT Lands Phones
Have purchased this producct plugged it in no ringtone no flashing to indicate incoming call have operational line with dialing tone, help please asap as only line into work
I am assuming that you can hear dial tone on the handset, and you can make calls on the phone. If this is correct, then I would recommend contacting BT and getting the phone replaced with one that works. http://www.bt.com/help/home/landline.html
Apr 16, 2015 | BT Duet 210 Corded Telephone - White
Trouble dialling out - swamped by 'please insert coins on answer' message
inform the network provider
someone has hacked in and using to make free calls
let the network providers reset ontheir system
Nov 27, 2014 | British Telecom Contour 50 Corded Phone...
Why no dial tone??
have you plugged your new phones telephone line into the telephone socket?
Aug 01, 2014 | BT 4500 Cordless Phone - DECT - Satin...
Bt contour 100 cannot make chargeable calls wants pin number
You will need the key to be in the lock while you enter the pin - this seems so obvious but can easily be forgotten.
Jun 25, 2012 | Lands Phones
How easy is it to to replace battery in a Contour 50 payphone? One site says the soldering will blow the chips. Terry
HI,
I have just replaced the battery on a similar phone today (not a BT one, but a "Payphone Link 20", its belgian counterpart).
It was a bit tricky as the battery is soldered on both sides of the circuit board, but the battery was replaced in a matter of minutes and the phone works fine now.
I wouldn't recommend this to the novice however. You need good soldering skills + equipment, and basic knowledge of how to handle a circuit board without damaging it (i.e. short circuit or electro-static discharge).
If you're not sure, I would advise you to get it done by someone familiar with electronics repair. Otherwise there are several companies that could fix it for you : you send them the front of the phone by mail, they replace the battery, clean and check the phone, and send it back to you.
Jul 28, 2011 | British Telecom Contour 50 Corded Phone...
Fitting a new battery to a bt contour payphone
I have a bt contour 100 that had the same problem no dial tone and nothing on the screen this is easily fixed by soldering in a new battery or soldering in a battery holder / battery back that takes 3 aaa batteries in place of the old battery you may have to solder two separate wires into the positive side and one wire into the neutral side after the old battery has been removed once you have soldered two wires into the positive thoes two wires need to be connected to the positive side of the battery holder and the other single wire into the neutral side of the battery holder once done correctly when you have inserted 3 AAA batteries and reset the payphone it will start working again bare in mind when you reset the payphone the pin number will go back to its default setting you may have to contact bt payphone help desk to get the default pin if you don't already have it there is a company offering to convert the bt contour payphone to run on regular alkaline batteries which are easily replaced but getting it professionally converted would come at a cost you can easily do it yourself giving some basic knowledge of electrical wiring and some common sense. The payphone runs on a 3v dc lithium battery that costs £9.99 on some sites on the Internet I believe that you can also get it to work on a 3v DC adapter but I have not tested or tried running my payphone on a power adapter as converting it to run on aaa batteries is easier and quicker to replace
Nov 03, 2009 | Lands Phones
Bt contour 50 phone is completely dead. no display, dial tone. replaced cords Done all resets that manual say. not sure of water damage, but circuits and box all dry
Yeah, the internal battery is probably exhausted. You can replace it with a new one, which you can get on eBay, but you probably need to know how to solder it in
Jul 15, 2009 | British Telecom Contour 50 Corded Phone...
BT Studio 1000 4 handsets
To Mrs Sue Groom,
You probably need to register the handsets to the base.This is the user manual for the BT Studio 1500
http://www.shop.bt.com/content/uni2/documentation/43py/023626.pdf
Mar 21, 2008 | Xact Communication XG2200 Cordless Phone
Lands Phones Logo
916 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
